Old 02-09-2009, 09:10 PM   #1
Caboose73
Need some help
Can anyone with Hptuners flash the GM supercharger reflash onto the new pcm im buying from quad4ld9?
Old 02-09-2009, 09:29 PM   #2
hptuners is to customize flashes. you will have to take it to a friendly gm garage and have them change the vin in the pcm and then they can put on the flash. there is a thread somewhere that gives u the number they need so they don't have to so on the phone to find them, saves a lil labor cost
Old 02-09-2009, 10:28 PM   #3
Yes you can "Write Entire" and put the GM supercharger recalibration on. VIN is not an issue.
Old 02-09-2009, 10:36 PM   #4
ok then just listen to C2 and ignore me. i just guessed from wat i've heard i never have actually used hptuners.
Old 02-09-2009, 10:38 PM   #5
I don't see why you'd want to by a new physical computer though to do it. Is something wrong with the one that's in your car?
Old 02-09-2009, 11:25 PM   #6
Caboose73
mines a 99 i know the reflash will "work" but i dont want the dummie lights on
Old 02-10-2009, 02:12 AM   #7
$50 for a PCM and having someone who has the 2000 model year unlocked on their HPT would surely be cheaper than any other way of getting the re-flash.
Old 02-10-2009, 09:58 AM   #8
Didn't think of that, forgot he was 99. Lol. I could flash it for you... if I could somehow hook it up to an OBD2 connector.
Old 02-10-2009, 02:07 PM   #9
I could make a harness for that, but I don't have any 2.4 PCM connectors. The 3400 ones show as a different number.
Old 02-10-2009, 06:00 PM   #10
Caboose73
the pcm im buying says it comes with the harness and connectors
Old 02-11-2009, 06:10 PM   #11
spyhunter
spyhunter's Avatar
the GM reflash fits onto PCM's with cars that do NOT have EGR. Get an 00+ PCM make a jumper harness as some pinouts have changed most likely. This isn't the most difficult task at all. Then once you have that all setup, just use HPTuners to flash in the 2bar GM s/c software update into your new PCM. Then you can tune and use the 2bar goodness.
The ONLY issue I would think of but I'm not entirely sure about is whether 99 has a BCM or not. Yet, jbody guys that have swapped over I have not heard of having any issues either.
Old 02-11-2009, 07:15 PM   #12
Caboose73
In the sticky it says the pin outs are the same for the grandam so i wounder if they would be the same for the alero if so then the only issue is if i have a bcm so can anyone flash this for me
Old 02-11-2009, 11:18 PM   #13
sburke
sburke's Avatar
sburke is an unknown quantity at this point
Not trying to crap the thread, just didn't think this question justified a new one......
ION - if I'm purchasing a supercharger and a hptuner can you send the entire file, or do I still have to pay to have some dealer to reflash it first?
99 Alero 3.4l GLS - Totalled
95 Avenger ES - Sold
01 Alero 2.4l 5spd - Sold
06 Mazdaspeed 6 - Current Vehicle
sburke is offline   Reply With Quote
Old 02-12-2009, 12:51 AM   #14
No you just Write Entire with the .hpt file I'd send.
Old 02-12-2009, 02:10 AM   #15
A '99 with EGR is identical to a 2000. No different pins or anything.
Yes, '99s do have BCMs.
Old 02-12-2009, 04:08 PM   #16
Caboose73
So then theres no problem at all cause i dont have an egr so can anyone do this or am i going to have to go beg a dealership?
Old 02-19-2009, 08:57 PM   #17
Caboose73
Bump so no one can do this?
Old 02-19-2009, 09:06 PM   #18
Yeah, put it in your car, and then connect to it with HPTuners and "Write Entire" using the .hpt file I'd send you. It's not like you can really interface with just the computer alone. Need an OBD-II port.
Old 02-19-2009, 10:11 PM   #19
Caboose73
Well i was planning on running MS-2 so i didnt want to drop the money for hp tuners to use it once
Old 02-19-2009, 10:58 PM   #20
spyhunter
spyhunter's Avatar
I'd be able to flash it, but i ain't flyin out there.
If you just want to flash the basic tune and have a not ideal tune w/ the extra mods you'll have on top of the supercharger that's up to you.
