Old 05-28-2009, 01:41 AM   #101
Spilner521
Boost Guru
Spilner521's Avatar
Originally Posted by Caboose73 View Post
Exactly what im going to do what intercooler are you running cause that tucks in nicely behind the stock bumper ?
Here's what you want, it'll tuck up behind the stock bumper quite nicely. Mine is almost the same dimensions, this one is just thicker
http://www.extremeturbosystems.com/M...duct_info.html
Old 05-28-2009, 02:35 AM   #102
Originally Posted by Spilner521 View Post
I've seen better, but those welds aren't terrible. Like I said, aluminum is tough to weld and make look good unless you have a lot of practice. The proper equipment doesn't hurt either.
I was thinking of something more like this, like a perfect row of dimes
oh DAMN.....those are some nice welds right there. i hate TIG welding......its frustrating i did some decent welds but that was just on regular sheet metal.....aluminum.....forget it
Old 05-28-2009, 02:41 AM   #103
Spilner521
Boost Guru
Spilner521's Avatar
Nah TIG is easy. It's so easy to control.
Old 05-28-2009, 04:15 AM   #104
It's just having an AC TIG for aluminum... Not within most peoples price range.
Old 05-28-2009, 08:08 PM   #105
Caboose73
9.1 Wiesco Pistons
2.3 Oil Pump
P&P Head
Bore 20 Over
SS valves (1mm over)
LMZ stage 2 cams Valve Lift INTAKE 260* - 377 EXHAUST 268* - 375
Bronze Valves Guides
Machine Block for 2.3
Rebuild Head
Boil Block
Arp Main bolts
Arp Head studs
Stiffer mantapart springs(Not to crazy about them but OEM says they have it in there 2.4 and its doing fine)
Eagle Forged Rods
Cometic Head gasket
Now with that set up could i run stock tune for awhile or should i tune it first cause of the cams?
Old 05-29-2009, 01:45 AM   #106
wrestlingandrunning
wrestlingandrunning is on a distinguished road
You should tune it first, cause you could do damage to your motor
wrestlingandrunning is offline   Reply With Quote
Old 05-30-2009, 04:45 PM   #107
spyhunter
spyhunter's Avatar
9.1 Wiesco Pistons
2.3 Oil Pump
P&P Head
Bore 20 Over
Rebuild Head
Boil Block
Arp Main bolts
Arp Head studs
Eagle Forged Rods
Cometic Head gasket
the only thing really affecting your tune is the cams and head porting. The car will run fairly okay on the stock tune, but it'll probably be wanting some changes in the top end.
Old 05-30-2009, 04:48 PM   #108
spyhunter
spyhunter's Avatar
go big dog!
Old 06-01-2009, 05:55 PM   #109
Spilner521
Boost Guru
Spilner521's Avatar
Too bad half of it will be covered up, and that's if it fits behind the stock bumper.
Old 06-01-2009, 06:23 PM   #110
DOHC_tuner
DOHC_tuner's Avatar
9.1 Wiesco Pistons
2.3 Oil Pump
P&P Head
Bore 20 Over
Rebuild Head
Boil Block
Arp Main bolts
Arp Head studs
Eagle Forged Rods
Cometic Head gasket
Get a tune but you can run without it for now....the engine will cry out for a better tune so get on it. Plus with stiffer springs you wont fully benefit from them until you raise your Rev limit. Then you'll feel the difference
Old 06-01-2009, 07:44 PM   #111
spyhunter
spyhunter's Avatar
I guess you don't know what I'm going to do to my bumper do you? And at 10inches, it's not ginormous tall either. The cake is in the width and thickness. And yes it fits behind the stock bumper. I don't have a crush beam in my way, nor do I need a front license plate, and my bumper is more open than an alero's anyway.
Old 06-03-2009, 03:05 AM   #112
Spilner521
Boost Guru
Spilner521's Avatar
Sweet.
I was talking about a stock Alero front end. Obviously almost anything can be made to fit, especially without the crash beam.
If you want to start talking about other cars, my intercooler will be even bigger than that
Old 06-05-2009, 11:58 PM   #113
Caboose73
Oil pans done
Well he finished the oil pan and i should have pics of the head when it gets picked up from the machine shop monday
Old 06-07-2009, 08:36 PM   #114
Spilner521
Boost Guru
Spilner521's Avatar
Very nice!
Old 06-07-2009, 08:48 PM   #115
DOHC_tuner
DOHC_tuner's Avatar
Looks great...even an additional drain plug?
Old 06-07-2009, 09:37 PM   #116
Caboose73
yup now i have two drain plugs so i can drain my oil twice as fast as any one else
Old 06-14-2009, 06:53 PM   #117
spyhunter
spyhunter's Avatar
Sweet.
Like this 4inch thick piece of nonsense?
Old 07-01-2009, 08:58 PM   #118
Caboose73
finally an update
My P&P head with 1mm over sized valves and LMZ stage 2 cams
Block will be done tomorrow ill post pics of it when i get a chance
Old 07-01-2009, 09:01 PM   #119
very nice!
Old 07-02-2009, 11:34 PM   #120
Caboose73
Moving the rest of this to the showcase forum so more people will see it
