07-27-2013, 02:28 PM
#61
Originally Posted by Nas Escobar
Get aluminum/alloy wheels. They're a lot lighter than the chrome ones you have now. That's really your problem. I never bought rims for my cars because I can never find anything lighter than my stock wheels that didn't look tacky.
My 18s are 2 lbs lighter per wheel then my 16s.
Originally Posted by Oldsnut
Originally Posted by tipnitty
07-27-2013, 02:44 PM
#62
Are you referring to your old American Racing wheels? Because my OEM 16" alloys were less than 17 pounds each...I kinda doubt your 18" wheels are lighter than that.
Rule of thumb is that a "light" wheel weighs 1 pound per inch of diameter.
What do your 18s weigh?
07-27-2013, 03:06 PM
#63
Yes my AR wheels. Never had stock wheels with my car. My uncle bent 2 of em hitting a pothole back when he owned the car, so thats why my car came with the AR wheels
AR estrellas 16" - 20.44lbs
MSR 18" - 18.90lbs ship weight.
Thats weight for just rims, no tires added on.
07-27-2013, 04:32 PM
#64
Originally Posted by jackal2000
Unless he has different cam the torque curve didn't go anywhere. I set my WOT shift points at 6200rpm with milzy's stage 2 cam.
What's all In the tune in your PCM
AwesomeNess
07-27-2013, 09:47 PM
#65
What's your 1st gear ratio? I was trying to figure that out vs. the stock automatic, w/stall speed figured in.... help me out here, Matt. lol
07-27-2013, 10:00 PM
#66
2005-06 G6 6 Speed
MT2/F40
axle ratio 3.55
1st 3.77
2nd 2.04
3rd 1.32
4th .95
5th .76
6th .62
07-28-2013, 12:44 AM
#67
my stokers weighed 34 with tire my 18s are 42 with tire
07-28-2013, 06:02 PM
#68
Everywhere. You want serious power... Boost it
When you goiing to freaking turbo your alero lol
AwesomeNess
07-28-2013, 06:16 PM
#69
When i have 25 grand lol
07-28-2013, 07:04 PM
#70
haha, pretty funny....
relocate your battery now, or nobody will ever take your turbo thread seriously
07-28-2013, 07:39 PM
#71
Not worried about the battery now. But since were on topic, where would i get the relocation kit?
07-28-2013, 07:58 PM
#72
make one
07-29-2013, 12:18 AM
#73
This.... its always a good idea to try to keep the weight of the wheel (with no tyre) to the size of it or less.
You have to make you own kit. You need a battery box, some 2 or 4 gauge wiring, new battery terminals and a new battery... this would be a good time to convert the battery to top posts if you want. I prefer it since it's easier to add the wiring than in a side post set up.
1994 Olds Cutlass Supreme
1996 Infiniti G20
1993 Chevrolet Lumina Z34
1989 Buick Regal Limited
07-29-2013, 12:28 AM
#74
Thanks ill look into it.
07-31-2013, 01:02 PM
#75
Lol I Am starting from scratch with my turbo kit.
AwesomeNess
07-31-2013, 02:11 PM
#76
Go ahead, its high stakes for me.
08-14-2013, 09:31 PM
#77
Wednesday, August 14th 2013.
At the track, so far i have not beat my best time as last time (15.1) but for my second time at the track i have gotten great RT's.
So far best slip is...
Car #8
Dial ...
R/T ... .022
60'. ... 2.534
330 ... 6.610
1/8 ... 10.009
MPH ... 72.48
1000 ... 12.904
ET - 15.391
MPH - 90.22
Now on the passes tonight i havent been launching it hard, got one pass to go before track shuts down, gonna try and make it a good one.
Good thing on not launching hard, done like 8 passes and no wheel hop.
But for second time at track im very happy with a .022 rt, also got another rt of .090
08-14-2013, 10:02 PM
#78
i run the same ET but my MPH is 95 ish
08-14-2013, 10:39 PM
#79
My best was 15.1 at 87 mph
Well last run i got a 15.25 at 91 mph flat.
Need slickz yo
08-14-2013, 10:58 PM
#80
You need to start keeping records of the track conditions, tire psi, IAT, ECT and all that. Best of all, get something to datalog the runs, HP Tuners is invaluable at this point.
If you ran 9 runs, that means you probably were not getting enough cool-down time. No doubt if you run on a cooler day, where the high is 65 degrees or so, it will run a 14.9xxx. with a good cool-down. iirc, ORP did not have a source of water for cooling, so that makes it tougher.
