Old 11-23-2005, 01:55 AM   #61
Oldsman
Owner
Oldsman's Avatar
Originally posted by cannaert@Nov 22 2005, 04:04 PM
Well i got one for you. Ok just put mine in as well. I when i turn it on and start to drive it stays in Frist gear. Wired up like Oldsman did I might tak it out and do it like 01WhiteOSV did.
sounds like it is wired up wrong.
don't go by the wire color at the plug but the pin location. this is what is important.
i would double check the pins, the wire color to the right pin.
also did you disconnect battery for 20-30 minutes before you tried it?
Beware of the BackStabber
Old 11-23-2005, 02:01 AM   #62
cannaert
cannaert's Avatar
cannaert is an unknown quantity at this point
Send a message via AIM to cannaert
No i did do the battery. Thnaks oldsman Ill try that in the moring
DONT BUY A JEEP.
It will take over your Life.
cannaert is offline   Reply With Quote
Old 04-08-2006, 10:59 PM   #63
sofa
sofa's Avatar
sofa is an unknown quantity at this point
Send a message via MSN to sofa
Old a$$ thread but to help anyone out when i hooked it up the first time it was into my A/C lol. make sure ur a/c works if it doesnt ur on the wrong wire.
Straight.From.Steel.City
http://www.cardomain.com/ride/2313940 http://www.myspace.com/kowch
sofa is offline   Reply With Quote
Old 04-09-2006, 11:56 AM   #64
Oldsman
Owner
Oldsman's Avatar
how did you hook it up to your a/c???????????
Old 04-09-2006, 12:54 PM   #65
sofa
sofa's Avatar
The blue wire under the dash i suppose. its nice out today im going to try and figure it out maybe the other blue and white? lol. well see.
Old 04-09-2006, 03:35 PM   #66
sofa
sofa's Avatar
i got it guys theres 2 red and black wires down there. the one furthest left is the right one.
Old 04-10-2006, 02:08 AM   #67
Oldsman
Owner
Oldsman's Avatar
that is why i ran it to the tranny plug. it is a more certain way of thw correct wires.
Old 04-15-2006, 05:23 AM   #68
Maybe this will help.
Old 04-16-2006, 12:43 AM   #69
sofa
sofa's Avatar
w00 not at all lol. yeah oldsmans right,run it to the tranny plug. under dash is hard to get @,
Old 04-17-2006, 06:06 PM   #70
AlbinoMonkeyRat
Let's Play Army!
AlbinoMonkeyRat's Avatar
I just bought one. Not in my possession yet...just doing some research.
Is the tranny plug the one almost directly behind the driver side high-beam light? If so, this shouldn't be so hard to splice it up.
Mounting will be my issue. I don't know where this grommet/hole in the firewall is...
Old 04-18-2006, 01:18 AM   #71
Oldsman
Owner
Oldsman's Avatar
no not really.
it is by the radiator hose on the driver side. find where the hose meets the rad then follow it back and you should see this.........
Old 04-18-2006, 10:38 AM   #72
2fst4u
[boosted 2.4L]
2fst4u's Avatar
has anyone else experienced a trac off, SVS light, and ABS light from the shift kit? the new tranny i put in hates my shift kit. apparently there is a tech bulletin about the solenoid that controls line pressure in the 2000-2003 aleros, all automatic trannies. i can't drive with mine on anymore.
Old 04-19-2006, 02:27 PM   #73
AlbinoMonkeyRat
Let's Play Army!
Originally posted by Oldsman+Apr 17 2006, 11:18 PM--><div class='quotetop'>QUOTE(Oldsman @ Apr 17 2006, 11:18 PM)</div><div class='quotemain'><!--QuoteBegin-AlbinoMonkeyRat@Apr 17 2006, 03:06 PM
no not really.
[/b][/quote]
okay. Yeah, I got the plug. (next to the battery) Where's the hole in the firewall? lol
Old 04-20-2006, 04:30 PM   #74
AlbinoMonkeyRat
Let's Play Army!
Old 04-20-2006, 04:40 PM   #75
2fst4u
[boosted 2.4L]
2fst4u's Avatar
the hole you want to use is the main wire grommet on the firewall. it's on the driver's side on the firewall. use a coat hanger to bull the wire through from the cabin side. this will keep all the electronics on the inside of the car, and the wiring in the engine bay. let me know if you need more help.
Old 04-20-2006, 10:16 PM   #76
Oldsman
Owner
Oldsman's Avatar
my trac off light goes on but that is it. it does cause a soft code.
Old 04-21-2006, 08:05 AM   #77
AlbinoMonkeyRat
Let's Play Army!
I only get the trac light in mode 2.
Old 05-01-2006, 09:50 AM   #78
rogan19
will this work on my 2001 auto 2.4L ?
Old 05-01-2006, 11:32 AM   #79
2fst4u
[boosted 2.4L]
2fst4u's Avatar
sure will. no problem
Old 05-02-2006, 04:36 PM   #80
rogan19
nd how does it chirp
do you drive gear to gear or just leave it in D drive
