04-29-2013, 09:38 PM
#761
its a twin loop threw muffler. its a little quiter then the thrush turbo i had one there but it gives it a deeper tone and sounds a hell of a lot better. the lateral link is a factory one from a 09 impala. replaced both and not to sounds stupid but i cant remember the name of the other bar that runs parallel to the lateral link. it can be replaced with the same thing. rims a from a 04 acura rsx. i was thinking about plastidipping them but idk if i wanted to be a rooster and do them white ahhasha.. if it looks horrid i can always peel it off..
04-29-2013, 11:42 PM
#762
Mods: Lowered on Canuck springs(1.75") on KYB GR2 struts with monroe mounts. SC/T hood/spoiler. Amber corner black housed headlights. Red LEDs for window/lock switches. White LEDs for map/floor/glovebox lighting. DRL and ALC delete. 20% Tint. 35w 3k HID fogs. Sport Edition KV5 Silver painted 18x8 35mm offset. Bridgestone Potenza RE970AS Pole Position tires. Badge delete. 12" PowerSlot slotted front brake upgrade w/ firebird dual piston calipers, rear slotted rotors. Borla Cat-back exhaust.
04-29-2013, 11:58 PM
#763
like em?
my baers stop on a dime! lol
Originally Posted by Oldsnut
Originally Posted by tipnitty
04-30-2013, 12:06 AM
#764
well, after 45 minutes, finally got it done
old one was pretty shredded as I found out!!
04-30-2013, 12:23 AM
#765
Hey, can you tell if it raised up the engine any with the new one?
Only 45 minutes, was it that easy lol
04-30-2013, 12:25 AM
#766
very nice
04-30-2013, 01:45 AM
#767
not too sure... I had the engine braced with a jack... I noticed it lifted a bit when I put in the motor mount a couple weeks ago... with this mount, it looked like there was a bit of play in the cross bolt holes which would more or less keep things at the same level but with the torque on the mount it holds it in place? hard to see down there, just going off what I could feel...
as for the time, I probably spent about an hour the last time I looked at it trying to figure out my plan of attack... tonight I had the time to play, so I went to town
braced the motor, took out the cross member, then the other 2 bolts, pried the old one out, stuffed the new one in... put the socket on the top bolt to hold it in line, started the threads, then tightened the bottom one... then the top, then the cross bolt... done
04-30-2013, 09:12 AM
#768
tw0123 where did you get the mounts? and last night i got bored and decided to do something about the tail lights.. i felt they were wayyy to big for the car so i tried to make them seem smaller. can still see all the lights with no problems and the reflector is still visible. this will do until i get ga bumpers then ill make a set. already have a couple ideas since i wont need the reverse light in the housing anymore!
04-30-2013, 09:22 AM
#769
mounts are found at milzymotorsports.com
04-30-2013, 11:50 AM
#770
Those tails look like my old set i just swapped out..
Next up for me is to try and tackle the sway bars... been putting it iff for a year now and with no suspension in the way i really am out of excuses hahaha!!
04-30-2013, 12:51 PM
#771
will ga sway bars fit?
04-30-2013, 01:05 PM
#772
basically all chassis parts for the 99-05 grand am works on the alero
04-30-2013, 01:06 PM
#773
double post
04-30-2013, 05:54 PM
#774
i washed my car today and was looking in the hood and noticed these areas were a lil damp.. possible leakage.. can someone tell me what this can be and how much it would cost.. the 1st couple of pix are from the dried cracked hose on top that goes from engine to air intake.. the 3rd and 4th are from the power steering reservoir. wondering if i need to replace that? and the last 2 are from around the gasket right underneath where you put the oil in the engine..
2004 GL1 2.2L Ecotec 160k mi. (Olympic White)
8000k 35w HID's
30/ 30 LED Switchback Turn Signals
JVC kw-hdr720 Double Din Head Unit
Polk Audio DXi691 Coaxial & DXi461 Plate Speakers
White/Glossified Plasti-Dipped OEM 15" Rims
Red Painted Brake Calipers & Drums
CarDomain home page is pretty much before pix.
The after pix haven't been taken yet... Still under construction
04-30-2013, 10:16 PM
#775
Nice Wheels TDavis !!
04-30-2013, 11:35 PM
#776
The only ones I see being worried about are power steering hoses...the one between the motor and the intake is ventilation and I would probably put a breather filter on there before bothering to replace the hose (mine looks like that as well) and the gasket under where you put the oil in is a problem area for the ecotec...a new gasket was put on when they did my timing stuff less than 10k miles ago and it already seeps there again, as long as you aren't losing a lot of oil it should be fine...If you are losing a decent amount of oil then the first thing I would do is pull the black intake box off and look at your throttle body plate...if it is covered in oil then the vent in the oil cap is clogged up so too much pressure is building up and throwing oil through the intake.
05-03-2013, 07:10 PM
#777
After about a year, I came home and finally received my Aleromod decals! I went right back outside and put em on!
05-05-2013, 01:33 AM
#778
05-05-2013, 10:35 PM
#779
Finally got it running right!!!! Then destroyed my tires, holy shit a tune woke it up. New tires Wednesday and paint following soon.
05-05-2013, 11:04 PM
#780
Grand Am - GT front bumper conversion, bolted on the rear caliper brackets, got a new rear caliper (one got messed up), and I should have it back in driving condition soon.
Cutlass Supreme - Fixed the top (finally! no more manually putting the top up or down), vacuumed it, and got some trim pieces for it.
1994 Olds Cutlass Supreme
1996 Infiniti G20
1993 Chevrolet Lumina Z34
1989 Buick Regal Limited
Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
