Originally Posted by billytheman1188
Got mine from a junkyard with 25k on it....runs PERFECT. Nothing wrong with getting them from there. Good luck with the swap....take your time and make sure you did everything right.
Did i ever said that engine from junkyard was no good? no!
All i am saying is to be careful , you know better be safe then sorry...
If i can't be sure of something or any doubts what so ever i let it go , i take no chances , specially with money...
But this is what i don't get , from what i can understand he want to swap the 3500 in the car with the 3400 heads on it with the bad valve seals?
Then that is a big waste of time & money since he'll have to fix the head anyways to put it in on the 3500 , might as well just keep the 3400 engine & fix the bad valve seals & save lots of money
For the money spend better swap the entire 3500 & forget about the 3400 engine parts IMO
25k... maybe , maybe not?
If you can't see the engine in the car it's would be impossible for anyone to know the real mileage of the engine & specially if you can't start it to see how it run's
Worst case if i couldn't test/start the engine before buying it i would probably ask them (or do it myself) to take out the spark plugs & see how good or bad they are that would give me a basic idea of the engine before i buy
