Old 02-01-2012, 10:03 PM   #41
Caboose73
Caboose73's Avatar
Caboose73 is on a distinguished road
Send a message via AIM to Caboose73
Not sure but those were eagle forged rods that ended up going threw the block with only 30-40miles on them. But it sounded exactly like yours does until it did that.
Stupidity has an incredible ability to overcome almost any obstacle.
http://www.fquick.com/Caboose73
http://www.aleromod.com/forums/showthread.php?t=27805
Caboose73 is offline   Reply With Quote
Old 02-01-2012, 10:16 PM   #42
caboose's situation was unique, i wouldn't use it as a base
Old 02-02-2012, 07:03 AM   #43
Caboose73
Caboose73's Avatar
True im just saying thats the same noise i heard then that happened.
Old 02-02-2012, 08:52 AM   #44
Philbar71
Hmm. So its safe to say then that the bearings are pretty much done then?
Old 02-02-2012, 11:44 AM   #45
I don't think so. But you might as well start piecing together parts to build a stronger one to handle boost or somethin.
Old 02-02-2012, 01:28 PM   #46
turboalero
turboalero is on a distinguished road
Originally Posted by Caboose73 View Post
Ya my engine was making that noise then this happened.
is it just me or does eveyones engine blow a hole in the same place
turboalero is offline   Reply With Quote
Old 02-03-2012, 10:39 PM   #47
AZFire316
AZFire316 is on a distinguished road
weird question, but if you have an auto tranny, have you checked your converter bolts, or flex plate for cracking? it can also have a bottom end engine knocking sound as well. Also to me it doesnt sound like bearing failure to me, not quite loud enough and also rod knock does NOT get quieter when you rev the motor, it gets louder.
AZFire316 is offline   Reply With Quote
Old 02-03-2012, 11:18 PM   #48
also if the crank pulley bolt isn't as tight as it should be it can cause a knocking sound
Old 02-04-2012, 12:05 AM   #49
Philbar71
Not sure how i'd go about checking that other than tearing the motor out? Its certainly is an odd noise tho, when i hold it in gear and accelerateing lightly, but not soft, throughout the rpm range i can hear a strange clattering noise that comes and goes depending on the load.
Old 02-04-2012, 08:43 AM   #50
Caboose73
Caboose73's Avatar
You can take off the starter to look at the flex plate to torque converter bolts but to check the flex plate to crank bolts or cracked flex plate you either have to drop the tranny or pull the motor.
Edit:or you might be able to fit a flex camera in there to take a look i don't remember how much clearance there is with the starter removed.
