05-04-2009, 04:56 PM
#41
Originally Posted by Fast Eddie
Like I said, I've got dyno pulls that show a reduction in low end torque with a higher flowing exhaust, but, your still right
You don't race at 2000-3000rpm do you?
05-04-2009, 05:20 PM
#42
Owner
however if you hit max torque in this range and normally your going to launch in this range.....well as any drag racer knows torque wins races.
So if he is launching a 455 the above applies and if on the dyno he produces more torque with closed high flow exhaust rather than open headers or straight pipes this would lead that person to believe that a little bit of back pressure is better than none because it works best for his setup.
This is where the confusion and back and forth comes from.
Because my buddy with his GN has a 3.5" downpipe to a muffler right under the passanger seat so it is basically no back pressure and he produces more power than a closed high flow exhaust system so in this case it is the opposite.
It all depends on your setup, power band, fuel curve, etc.
Another example...........3" exhaust straight pipes on a N/A alero isn't going to produce more power or better ET than that same alero with a SLP exhaust system.
Beware of the BackStabber
05-05-2009, 12:26 AM
#43
I believe this was already discussed in the thread, when talking about velocity.
I launch almost at 4750-5000rpm, I have different ideas of launching. :-D
05-05-2009, 10:29 AM
#44
Boost Guru
I know your theory does not apply to all motors and every setup out there.
So unless you have built every motor known to man and every setup possible and dyno tested all of them, your chickenyness is only that.
Regardless of which engine we're talking about, and my apparent "chickenyness", you still want the least amount of backpressure possible.
It may lead someone to believe that backpressure is making more torque, but in reality the setup that makes less torque doesn't maintain high velocity to maximize the scavenging effect.
Throwing a turbo in the exhaust stream is a different story. You want large piping to get all the restriction and backpresure off the turbine wheel so it'll spool faster and make more power by staying spooled longer. The largest, straightest, shortest exhaust pipe is the best for a turbo.
Again, this goes back to velocity. The 3" system will make more power, but it'll peak higher up in the rpm band. With smaller piping, yet still free flowing mufflers, the exhaust will have higher velocity and therefore make more low end torque, with the possibility of slightly lower peak, high rpm horsepower.
05-05-2009, 10:42 AM
#45
New and Improved
ah the good old backpressure debate.
05-05-2009, 12:02 PM
#46
Owner
this was my point. And depending on your power band of your setup it determines which exhaust setup is best for your car.
05-05-2009, 01:53 PM
#47
Sounds great. Post 'em up, along with the specs on the engine and exhaust.
I know I'm right
They are at home. I'm not sure where they went (over 5 years old) and not interested in looking for them. Like I said, I really don't care that much about the performance of the 'ho any more. I'm also not interested in arguing over the Internet, so if it makes you feel better you can be right
Have a nice day!
I'm on a boat.....
05-07-2009, 03:29 AM
#48
Boost Guru
Exactly, that's kind of what I was getting at in the first place. How the car is going to be used determines the exhaust setup that will work best to maximize torque and horsepower. And regardless of how the car is being used, backpressure is still your worst enemy in an exhaust system.
Have a nice day!
That's ok Eddie, I figured they'd be lost I'm not trying to start a fight, I could care less about arguing over the internet, I was just correcting some false information so other people that don't know can get the right information.
