Old 05-17-2012, 08:44 PM   #421
happyisthealero
happyisthealero is an unknown quantity at this point
Good to know thank you. How does the handling differ with the thicker sway bars and lowered stance from lowering springs? the reason I ask is because I have eibach pro waiting to be installed.. Oh and when I get the money I would like to buy AGX adjustable springs.. Just wanted to throw in any and all possibilities.. thanks aaron
happyisthealero is offline   Reply With Quote
Old 05-17-2012, 09:43 PM   #422
Originally Posted by mfuller View Post
I used both on my car and it was neutral. If you do just the front bar it understeers like a pig; just a rear bar and the ass-end gets pretty skittish.
They will really draw attention to shitty tires.
sounds like it's time to upgrade wheels/tires now! and brakes while I'm at it..
Old 05-17-2012, 11:49 PM   #423
jabartram
AutoCross Alero
jabartram's Avatar
excellent tires, excellent brakes, great suspension, these should swing me around the autocross track nicely, my car already wheel lifts in the rear on hard corners, that crossbrace i made solidified the rear.
Old 05-21-2012, 08:49 PM   #424
mrmike
mrmike's Avatar
mrmike is an unknown quantity at this point
So does anyone have them on yet? I'm curious about the difference.
mrmike is offline   Reply With Quote
Old 05-21-2012, 09:15 PM   #425
colonel6632
colonel6632's Avatar
have mine installed, love em! installed with a breeze. car feels so much stiffer with much less body roll
Old 05-21-2012, 09:27 PM   #426
The front was a breeze? Dont you hav to drop the cradle?
Old 05-21-2012, 09:30 PM   #427
happyisthealero
make a how-to!
Old 05-21-2012, 09:33 PM   #428
happyisthealero
I think I read, from someone in this thread, that these would not work with our sway bars is that true?
http://www.pfyc.com/pc/GA4008/ALSUSP...or+N-Body.html
Old 05-21-2012, 09:48 PM   #429
I dony know for sure but the new ones are much thicker than stock, so unless you drill out the bushing somehow.. Its most likely a no
Old 05-21-2012, 09:58 PM   #430
colonel6632
two things.
1. those bushings are supposed to work i believe since it says they are for next level or speedbuilt. not factory.
2. ya the cradle has to drop. but its just 3 bolts on each side. and then there are 3 bolts for a mount thats attached to the cradle. pull them too, drop it
heres how i did it basically. there wont be pictures since i already installed them
1. lift front of car off the ground, supper each side with jackstands in a secure spot and remove jack. obviously dont put the jack stands on the subframe.
2. remove tires (optional) just makes life easier.
3. put jack in the middle of the subframe. near the back of it. you'll see where.
4, there is a... 22mm? bolt that goes through the control arm, sub frame, and then into the car. pull them on each side
5. then after those there are 2 little.... 15mm? bolts, pull those.
6. slowly lower the jack so the subframe and the engine fall down
7. there is also 1 bolt and 2 nuts that hold down a tranny mount i believe. i pulled that so that it just moves a bit.
8. remove endlinks.
9. pull the swaybar brackets... 15mm? bolt i believe. easy to pull
10. remove swaybar
11. do reverse and tighten everything
any questions feel free to ask, ill try my best
Old 05-21-2012, 10:43 PM   #431
installed mine today, made a write-up too!
http://www.aleromod.com/forums/showt...596#post617596
Old 05-21-2012, 10:45 PM   #432
Starglow
Starglow's Avatar
Starglow is on a distinguished road
So you didn't have to disconnect the tie rod ends or the steering intermediate shaft? Every procedure I've read so far says to do those steps.
two things.
8. remove endlinks.
10. remove swaybar
Starglow is offline   Reply With Quote
Old 05-21-2012, 10:59 PM   #433
no you do not.
Old 05-21-2012, 10:59 PM   #434
Starglow
Starglow's Avatar
I just ordered Energy Suspension grease-able bushings using the following part numbers taken from an older PFYC sway bar group buy post I found for the same bars.
ENS-9.5158 Rear
ENS-9.5164 Front
I did not buy the PFYC bushings because of the following statement at the bottom of the page on their website:
"You can use your existing brackets, they're not included with these bushings."
This statement is very misleading and because the PFYC price is a little cheaper than anywhere else I found, it's unclear if the brackets are included or not.
Old 05-21-2012, 11:24 PM   #435
Their saying "you can use these new bushings with the old brackets....but the brackets aren't included"....so if for some reason you needed new brackets, you have to buy them separate.
Old 05-22-2012, 07:03 AM   #436
Starglow
Starglow's Avatar
I still don't think that statement should be there at all and no other site that sells those same bushings has it, so I don't see any valid purpose for it other than causing customer confusion which is why I purchased my bushings from another site even though it cost me a bit more. But I didn't want to take any chances buying the PFYC bushings based on their product description.
PFYC also doesn't include the size information or Energy Suspension part numbers for reference, so there's not enough information provided for me to make an informed purchase decision to know exactly what I'm getting from them.
Old 05-22-2012, 06:52 PM   #437
i disagree entirely about them not putting that statement...if you take the time to read it (paying attention to wording
), it makes perfect sense what it says...I would be mad however if they didn't put it and you were expecting it to have new brackets because it doesn't say anything only to find out that there are none
Old 05-22-2012, 11:18 PM   #438
Starglow
Starglow's Avatar
Doesn't really matter to me now since I already have grease-able bushings on order from another website with a more clear product description.
Old 11-11-2012, 08:03 PM   #439
Mike The Canadian
Mike The Canadian is on a distinguished road
Big props to MMGT1 and his bro.
Installed the front and rear, did an amazing job, took great care of the car they were working on and a more than reasonable price.
Mike The Canadian is offline   Reply With Quote
