Old 06-27-2006, 11:20 PM   #21
projectalero
thanks for ur thoughts orion...I already run premium fuel in my car. About the disconnecting the air intake...it wont suck up too much dirt and particle will it? Being 19 i cant afford to damage my only vehicle.
Old 06-27-2006, 11:25 PM   #22
Pimpalero03
on the track u more then likely wont suck in anything. people do it all the time. practice launching cuz that will be ur weak point. i used to hold rpm at 1200 and let go of brake when launching. tires wouldnt spin as much. and put shifter in 2nd gear so u can hold it out longer.
Old 06-27-2006, 11:33 PM   #23
AlbinoMonkeyRat
Let's Play Army!
AlbinoMonkeyRat's Avatar
info from Wiki...
1996 240SX:
Engine: 2.4 L KA24DE I4
Wheelbase: 2525 mm (99.4 in)
Length: 4498 mm (177.0 in)
Width: 1727 mm (68.0 in)
Height: 1288 mm (50.7 in)
Curb weight: 1253 kg (2762 lb)
Specifications
* Bore × Stroke: 89.0 × 96.0 mm
* Max power: 155 hp (115 kW) @ 5600 rpm
* Max torque: 160 ft·lbf (217 N·m) @ 4400 rpm
* Valve Configuration: DOHC, 16 valves
* Compression ratio: 8.9:1, 9.2:1, 9.5:1
you have a chance, but it'll be REALLY close.
Old 06-27-2006, 11:36 PM   #24
AlbinoMonkeyRat
Let's Play Army!
on my 2.4L, I rev up to about 2500, but 2500 might be a bit much for the V6. if you can get a few test runs in, test in between those rpm ranges. You might find 1200 will be good, or you might find something higher works well.
Old 06-27-2006, 11:49 PM   #25
projectalero
I typically hold it between 1000 and 1200. It does spin a bit, but nothing too much. Im not so sure i can actually get mine to rev to 2500. Ill give it a few test runs and see what happens. By tha way...when i rode with this guy the day he got tha car, he was reving tha hell out of it. I watched the tach go well past 6000. Wouldnt that be a waste of time because you are supposed to keep the rpm's in the max power range. If you keep going past that you are just losing power and actually losing time. Correct me if im wrong guys, but that is just my thought.
Old 06-28-2006, 12:12 AM   #26
AlbinoMonkeyRat
Let's Play Army!
once you pass peak power, yes, you are wasting time, and causing unnecessary wear to the engine. That's why on autotragic transmissions, you won't hear the engine bouncing off the rev limiter when it's moving.
ideally, at the track, you want to rev as close to the power range as possible without losing a lot of traction. If you have stock tires, you might not want to rev that high.
Old 06-28-2006, 10:45 AM   #27
alero440
alero440's Avatar
alero440 is an unknown quantity at this point
Send a message via AIM to alero440 Send a message via MSN to alero440 Send a message via Yahoo to alero440
240sx= 155hp 160 torque. They are lighter then the monster aleros we drive. Now I've been in a stock 240 and they are quick little cars off the line. they have a decent power curve too. I've never raced the 240 in my car so I can't say yea or nay whether you'll win. It also depends on the driver of the car. If the kid can drive and keep the back end from spinning he may have a chance, but if he sucks and just sits there an spins them, you may have a chance. Who knows.
alero440 is offline   Reply With Quote
Old 06-28-2006, 11:01 AM   #28
Silentalero
Kitteh is back!!!!
Silentalero's Avatar
How sure are you that he is stock is the question. The 96 240 has a crapload of parts for it that youd never notice without spending anything.
Trust me, kids dont go talking trash asking to race unless they've got something under the hood..Keep that in mind.
Just do it at the track so nobody gets hurt, arrested or anything else.
97 Nissan 240sx - sr20det
94 Nissan 240sx convertible
01 Suzuki gsxr 750
Old 06-28-2006, 12:37 PM   #29
alero440
alero440's Avatar
yeah you can't see the Tien Superdrifts that are on the project car. They don't lower it much, but they are awesome in cornering and such.
Old 06-28-2006, 01:41 PM   #30
steve-o
Canadian... Eh?
steve-o's Avatar
steve-o is an unknown quantity at this point
Send a message via MSN to steve-o
but its a automatic, rear-wheel drive, 4 cyl... my buddy had an old 240 with a 2.4 , 5pseed, and my z24 would mop him up, i think you got a good chance dude
steve-o is offline   Reply With Quote
Old 06-28-2006, 01:44 PM   #31
steve-o
Canadian... Eh?
steve-o's Avatar
oh yeah, and my Z24 had 3.1, 5-Speed, and i shouldn't say I moped him up, it was close, but i would beat him
Old 06-28-2006, 01:51 PM   #32
AlbinoMonkeyRat
Let's Play Army!
simple as this:
3400 N-body> 2.4L J-body > 2.4L N-body
the 2.4L 240SX should be somewhere between the 2.4L GM's.
Old 06-28-2006, 02:31 PM   #33
ptrudel
Designated Drunk
^you sure albino?
i mean, yeah it depends on driver and lotsa other things, but no z24(2.4l) j-body will keep up to my alero
I'm baaaackk
Old 06-28-2006, 02:58 PM   #34
AlbinoMonkeyRat
Let's Play Army!
stock vs stock, dude. our cars have the same engine and I'm pretty sure the same transmission (gearing) and they are lighter cars. I guarantee that if you drove your Alero and you drove a Z24 down the same track, you'll have a slightly faster time in the Z24. (this way, it eliminates differences in driver weight and skill) You're probably a better driver than the people you raced in their Z24's if they can't keep up.
Old 06-28-2006, 03:04 PM   #35
ptrudel
Designated Drunk
maybe...i dunno if they were auto or stick either, and mine's a stick
I'm baaaackk
Old 06-28-2006, 03:25 PM   #36
projectalero
I looked at the car the other day. It does have a full interior and i did make sure its an auto. He popped the hood and everything seemed stock: air box, manifold, exhaust, even the pulleys. He may have something hiding inside the motor, but i cant tell. All i know is the guy bought it from an older lady a week ago. As far as the driver skill...im nothing special, but this guy seems like a idiot. He claims to be a badass drifter. My first thought is that he is more likely to spin out of habbit, rather than think about what he is doing...which is drag racing.
Old 06-28-2006, 04:05 PM   #37
AlbinoMonkeyRat
Let's Play Army!
I'm sure Z24's had both.
Old 06-28-2006, 04:07 PM   #38
AlbinoMonkeyRat
Let's Play Army!
you can't be a bad-ass drifter with an auto. lol Might accurately fishtail a couple turns here and there, but to be a bad-ass drifter you gotta have stick and be able to drift around pretty much any turn.
Old 06-28-2006, 04:10 PM   #39
alero440
alero440's Avatar
bad ass drifter eh? Tell him if he wants to be a bad ass drifter so bad he needs a better motor then the KA... It bogs down in 2nd gear doing figure eights. I think its kinda stupid having this debate whose better then who.
Old 06-28-2006, 04:16 PM   #40
ptrudel
Designated Drunk
Originally posted by AlbinoMonkeyRat+Jun 28 2006, 03:05 PM--><div class='quotetop'>QUOTE(AlbinoMonkeyRat @ Jun 28 2006, 03:05 PM)</div><div class='quotemain'><!--QuoteBegin-2000_olds_alero@Jun 28 2006, 02:04 PM
[/b][/quote]
lol...i know they were available with both..i meant about the ones i raced against
I'm baaaackk
