Old 10-15-2008, 10:42 PM   #21
0_0
what is so bad about dex cool anyway? i mean, the only thing i can see is that my saturn heats up real quick in the morning
Old 10-15-2008, 10:52 PM   #22
CactusWill
sludge city
Old 10-15-2008, 11:34 PM   #23
rustyballs_69
Its Beer Thirty
rustyballs_69's Avatar
Is the T-stat stuck closed?
Old 10-16-2008, 07:37 AM   #24
Beholder88
Beholder88's Avatar
Beholder88 is on a distinguished road
Originally Posted by Nate's Alero View Post
lol, i never liked mali's seem junky to me
It wasn't that bad of a car. Exactly the same thing as the Alero, just a different body skin. Mine had the 3100 though. The same Haynes manual that I used for the Malibu I can use on my Alero. Point being, I never mix coolant, regardless of what the bottle says.
Beholder88 is offline   Reply With Quote
Old 10-16-2008, 08:28 AM   #25
so, dex cool is bad in general? i mena it works for me
Old 10-16-2008, 09:39 AM   #26
CactusWill
In many cases. I have no sludge built up in the ecotec, but I do believe that it is a contributing factor to all of those 3.4's with gaskets that went bad prematurely.
Old 10-17-2008, 03:18 AM   #27
jwateland
jwateland is on a distinguished road
well dex cool can leave some sludge but it is nothing that will ruin your car. get a anitfreeze tester from wal mart or somewhere cheep when you put antifreeze in it hold it up to the light and you can see exactly what is floating around in there. as for your problem you need to do a pressure check of your cooling system. probably the simplest way is to go to a shop and watch them as they pressure test your system, and start from there. start by picking one general problem and focus there.
jwateland is offline   Reply With Quote
Old 10-17-2008, 07:27 PM   #28
Blktrax
Blktrax's Avatar
Blktrax is on a distinguished road
I bet one of the cooling fans took a dump or wasn't hooked back up in the repair, the Heater is just dispersing whats not being taken care of by the fans. Turn on the A/C max cold and BOTH fans should be running. Any time the temp needle is above half, one fan should be running.
One Bolt at a Time.
Blktrax is offline   Reply With Quote
