12-17-2007, 10:51 AM
#21
wow how nuch did u pay for your coilovers and where did u get them??? i searched ebay and found the for a average price of a G
12-17-2007, 11:13 AM
#22
V.I.P. Punching Bag
if i did my research properly, i think your going to be looking at anywhere from $650.00 to $1,100.00 for a set of good quality coilovers. i did a general search on ebay and the cheap $60.00 set for like a civic or any domestic car look way more different then that of a $1,000.00 set for a domestic car. i dont know much about this kind of thing personaly but im sure someone can correct me.
12-17-2007, 03:51 PM
#23
Originally Posted by pimpalero2003
20x7.5 then and thanks bro
no problem just trying to help ( i just never want it to tell anybody about the springs i want it it to be my secret ) but you were not going to get a good answer so i figure i help, get the springs and a set of these and you will almost ride like if you had a 1500 dollar suspension plus these struts are for lowered applications and they will last you a long time.
12-17-2007, 04:05 PM
#24
i got mine for 130 dollars almost 2 years ago on ebay , i was just looking on ebay and they dont have any ( i was like what ? ) but im going to look for a set or a site that has them for cheap , the springs have to be for that application of a car tho ,you can see the difference from these spring compare to the ones for a honda or any other car.
12-17-2007, 04:20 PM
#25
yeah im not going to pay a gino for springs 150 is a little better
12-17-2007, 06:17 PM
#26
Originally Posted by GA_turbo
Another cool thing you can do with the coilovers is that you can cut the old piece where the old sring used to sit and you can put up to almost a 10 inch wide wheel, thats what im doing to mine but im doing 20x9.... like the bottom pic .... so far so good i hope everything works for me cause i really like the look of this car like this
The wheels on this pic is photoshopped. You can't be bagged on 20x9 and be that low.
Theres a guy on forbidden (bodykit) website w/ 20x8.5 and he sits alot higher laid out.. than me w/ my 20x7.5 wide wheels.
those look like 22's they photoshopped on. It takes up more room than my 20's in diameter.
Also, they don't make 20 by 9 or 10" wide in FWD offsets, only RWD offsets. So it wouldn't tuck like that in pic.
12-17-2007, 06:22 PM
#27
ahh that was a badass ga
12-17-2007, 09:22 PM
#28
Owner
i have 18x7.5 on mine and did have 19x8 on the rear. but tires are 255/40's. the 18's are damn closer about 1/8" from the front springs and even with a 1" spacer on the rear i have 1/2" between the tire and the spring. with the 19's i had about 1/4" space in the rear.
so unless you have a 35 offset a 10" wide will not fit and tuck
Beware of the BackStabber
12-17-2007, 10:11 PM
#29
i know they are photoshopped but is a reference on how i want my car to look
if worst comes to worst my wheels will be 20x8 front and 20x9 rear with coilovers you can cut the old strut plate and you will have no problem fitting the wheels. Trust me im in the process of doing this as we speak. I will have pics when im done.
Also i want it to say that with any lowering spring you willll have a anoying bounce to it wether its in the front or the rear depends on the brand. Other than that they only way to avoid the bounce is to stay stock its that easy.
Oh by the way read this FWD 20x9..... i did my homework... like i said im in the process of doing this.
http://www.akwest.com/Platinum%20Series.html
12-17-2007, 10:19 PM
#30
i know when i saw this pic i was like damn , thats it , thats what i want my car to look like...... now im working on it the best i can so that the tires dont scrape anything
does it have tires on it?
12-17-2007, 10:25 PM
#31
what does the car on the pic
12-17-2007, 10:33 PM
#32
did u find spring yet and can i get pics of your setup with the coilovers
12-18-2007, 01:16 AM
#33
yea you can do 20 x 8.5 and 20 x 9. You just won't be as low as w/ a smaller width rim. But 20x10 is out of the pic. unless you use a BIG spacer, extended wheel studs and widebody the car. I know there is FWD offsets but more than likey not have one for our cars. Did you email them what offsets they come in?
12-18-2007, 01:48 AM
#34
http://www.amazon.com/Stealth-Non-Tu.../dp/B0009X54Z4
im still looking for something a bit cheaper. ill get some pics soon for ya
12-18-2007, 01:52 AM
#35
thanks bro ive been reading some old old threads and some said accord coilovers would work
12-18-2007, 02:10 AM
#36
yeah 20x10 way tooo big, what i want is a wheel with a 3inch lip thats why im doing this. Mostly will be for shows and just to cruise around also my car is turbo so the 20s are definetly for shows.
im trying to design a control arm for my car so that a buddy of mine can make them for me.
12-18-2007, 02:22 AM
#37
go with tis wheels always have a huge lip
12-18-2007, 02:36 AM
#38
You know the size of the lip is all about the offset size. Doesn't matter what brand of rim you go with.
normally RWD cars can have huge lips cuz they can run larger offer in the rear than FWD cars.
heres a bagged 350z RWD car .. they can do large offsets and wider wheels. Those wheels are like 19x9.5 front Offset +10mm and 19x10.5 rear Offset -22mm
12-18-2007, 02:58 AM
#39
mmmmmmmmmm
12-18-2007, 04:16 AM
#40
Damn now those have some big lips im not going that extreme... more like this with a nice lip: 2.5 to 3 inch lip.
