Old 10-09-2008, 10:29 AM   #21
?? 0_o ??
Old 10-09-2008, 11:27 AM   #22
so you replaced your axle and it fixed the problem, i dont understand why there are still more questions? lol
Old 10-09-2008, 12:45 PM   #23
whiteliquid
Defeat < Giving Up
whiteliquid's Avatar
whiteliquid is an unknown quantity at this point
Send a message via MSN to whiteliquid Send a message via Yahoo to whiteliquid
It didnt fix the problem...hence why i said the CV joint didnt fix the problem so now im changing out the front motor-tranny mount because thats what the GM mech recomended....
I was also wondering about bushings and where to get them...
WhiteLiquid
whiteliquid is offline   Reply With Quote
Old 10-09-2008, 01:08 PM   #24
sorry i misread what you wrote. you should be able to pick them up at any parts store or if you want to buy them online summit most likely has them.
Old 10-10-2008, 09:47 AM   #25
Fi-Alero
Fi-Alero's Avatar
Fi-Alero is on a distinguished road
I'm kind of having the same problem lol
Mine is shaking at 70+ in the steering wheel. It isn't bad, though. I just replaced my tie rod ends and it still is doing it.
I hope you figure this out so I can start looking at what i need to do.
Fi-Alero is offline   Reply With Quote
Old 10-10-2008, 09:59 AM   #26
bryan213
bryan213's Avatar
bryan213 is on a distinguished road
wobble
could be rack and pinion bushings. or loose hub
bryan213 is offline   Reply With Quote
Old 10-10-2008, 10:31 AM   #27
whiteliquid
Defeat < Giving Up
Rack and pinion bushings are good...so are the hubs.
I hope that its this front mount. IT looked pretty bad when i took it off the car.
For anyone that wants to know you can not replace the front mount with an aftermarket one. They are cheaper but you will also have to replace the bracket. The oem ones are a little bit oval shapped and have bumps that help hold it in place. The aftermarket ones are perfect circles and have tabs.
WhiteLiquid
Old 10-10-2008, 09:17 PM   #28
Blktrax
Blktrax's Avatar
Blktrax is on a distinguished road
Wow all this discussion and no one checked the lower ball joints.
Jack the front end up get the front tires off the ground (preferably on a lift). Turn off the trac control and run the car in 2nd gear, if you feel a vibration with the suspension unloaded, you got driveline/brake issues. If you dont, then its suspension related.
One Bolt at a Time.
Blktrax is offline   Reply With Quote
Old 10-14-2008, 09:22 AM   #29
whiteliquid
Defeat < Giving Up
Ball joints are good.
I think I'm going to replace the Rotors/calipers/pads today.
Prob going with cross drill slotted this time on the rotors.
Also would the drums have anything to do with this problem maybe????
WhiteLiquid
