08-12-2009, 11:20 AM
#21
Man that video of the run makes look like he's absolutely crawling. Weird. I almost thought it was an 1/8 mile run.
08-12-2009, 02:33 PM
#22
Yeah, Magnuson uses that same camera angle a lot, too.......
08-15-2009, 08:53 PM
#23
Its was also his first time running the car! And the block, heads, and cam are all stock. Why break it the first time out exspecially when your not used to it yet?
Atleast we know what the stock 3400 can hold right now!
08-15-2009, 09:28 PM
#24
true
spyhunter's run was done before he made 432whp too.. that was when he was only on a little over 300 if I recall correctly
Agreed.
I did it on a peg leg too.
Slicks help a lot when you're actually making a lil power.
08-15-2009, 09:37 PM
#25
we knew what the 3400 could hold before.......
08-16-2009, 05:23 PM
#26
Wide Open Throttle
He would have to dyno it to tell us anything about the motor. A purpose built car won't need as much power to run those times. He left a lot on the table with this setup but it will make whatever else he does look even better once he dials in it and gets used to the car. I look foward to the results.
08-16-2009, 10:16 PM
#27
After watching the video again and again with something not rubbing me right. I've come to a conclusion. His wheelie bars are touching the ground. While the car is at rest, and while the car is moving. That setup wouldn't be legal in sanctioned events I'm assuming, even in FWD events if this is true that wheelie bar wheel IS touching the ground. While the car is still it has to be free-spinning. From everything I have ever known. hmmmmmmmmmmmmmmmmmmmmmmmmmmm
08-19-2009, 01:27 AM
#28
3:6 WHEELIE BARS
All wheelie bars, regardless of class, must have non-metallic
wheels (i.e., rubber, plastic). Wheelie-bar wheels must turn freely
at starting line; any preload prohibited. Wheelie bars must be fixed.
Hydraulics, pneumatics, electronics, etc. or any adjustment or
movement during run prohibited. Using wheelie-bar wheels as “fifth
wheel” sensing device prohibited.
#29
Im pretty sure that they weren't touching but your right...
08-19-2009, 06:17 AM
#30
the video to me shows them touching. Either way, they seem to be faaaaaaaaaaaar too close to the ground and actually seem to be supporting some of the weight of the rear.
09-05-2009, 08:10 AM
#31
looks like the v6 n-bodys are starting to catch up to the v6 j-bodys!
this is the fastest 3400 powered Cavalier right now
http://www.youtube.com/watch?v=xnjfjCTDpZo
that vid was last year on Hot Rod's dragweek with a slipping clutch. This year his best was 11.94@119mph bone stock 3400 +13psi full interior and drag radials
little more info here > http://www.v6z24.com/jbodyforum/gett...9-t109693.html
2004 Olds Alero 3400 v6 15.32 @ 88.69mph Bone Stock
1999 Olds Alero 2.4 to 3500 swap (running), Ported heads. totaled by a honda
2002 GAGT 3500 swap. parting out
1993 c1500 turbo 3100 swap 5psi.
1976 Cutlass 350 olds stock for now
10-06-2009, 11:30 PM
#32
i think they were touching the ground as well.
10-07-2009, 01:08 AM
#33
Good call, man!! I see that now too. I didn't notice that before.
I didn't know the wheelie bar rules anyway. I haven't come to that part of drag racing......yet
10-27-2009, 09:45 PM
#34
Originally Posted by lvemy3100
meh... the car isnt even remotely close to stock...
as milzy stated int he thread
"Garrett T67 ball bearing turbo
custom 1 3/4" primary turbo headers
3" downpipe
1000+hp fuel system (A1000, 95lb/hr injectors, etc)
no accessories other than alt (electric water pump)
4t65eHD transmission with 3.29 gears and 4000 stall converter
26x11.5x16" MT ET Streets, 28x4.5x15" Moroso DS2 fronts, each on Weld Draglites
custom coilovers
custom tubular rear suspension
6-point roll cage with halo and A-pillar bars,
gutted interior
1 racing seat"
Holy Crap If I ran that much in my Honda I would run 10's.... Aleros really do somewhat suck hahahha
10-27-2009, 09:55 PM
#35
/\/\ ricer please...
10-27-2009, 10:55 PM
#36
bah I ran 15 and 18 psi with no breakage before. it was drastic altitude change that caused me to pop a slug.
10-27-2009, 11:16 PM
#37
That eBay turbo could produce that much pressure without blowing to bits? I'd get your hands on a Garrett soon if you plan on keeping the engine.
10-27-2009, 11:30 PM
#38
seriously wtf, thats the second n-body bashing post tonight (that i've seen). gtfo ricer.
10-28-2009, 12:04 AM
#39
Do you not realize that the Alero and Grand Am is the same thing.
Though if we have a ricer section can he be the mod for it?
2002 Oldsmobile Alero GL 1990 Nissan 300zx n/a 1991 Nissan 300zx TT
10-28-2009, 12:06 AM
#40
and he received an infraction for one, and a warning for the second one stating that if he trys to start problems again with his honda loving he is getting a ban.....
