Old 02-13-2005, 12:29 AM   #21
FrankNY
FrankNY's Avatar
FrankNY is an unknown quantity at this point
Send a message via AIM to FrankNY
Thanks! :thumbsup:
FRANK
2001 Alero GL
FrankNY is offline   Reply With Quote
Old 02-13-2005, 12:47 AM   #22
Screamin eagle
Screamin eagle's Avatar
Screamin eagle is an unknown quantity at this point
Send a message via Yahoo to Screamin eagle
If you do this mod and you drill holes in the LED tail light, be careful where you drill your holes. When I did mine, I drilled out some stuff on the board and I had to repair it. Just pay attention to where you drill. I think I paid $25 from carparts.com
http://www.myspace.com/knoxy66
Screamin eagle is offline   Reply With Quote
Old 02-13-2005, 01:22 AM   #23
02_Silver_Ho
02_Silver_Ho's Avatar
02_Silver_Ho is an unknown quantity at this point
As well as rmulax19, I bought a pair of these LED bulbs from Checkers (dont know if anyone has it by them) right when I put them in, blew a fuse right away, why is that happening? I dont know why these shouldn't work, they say 3157 right on the package, any help? Maybe I was rushing putting them in the first time and blew a fuse, but i'd like to know for sure that these will work before buying another box a fuses.. Thanks
Need to change my sig pretty soon, unless a miracle happens...
02_Silver_Ho is offline   Reply With Quote
Old 02-13-2005, 01:34 AM   #24
Screamin eagle
when you push the bulbs in, make sure that the metal pins on the bulb are straight, only thing I could think of is if the metal pins were touching something and grounding out.
Old 02-13-2005, 01:53 AM   #25
02_Silver_Ho
That sounds possible, because when I put the bulb in, I heard a noise, most likely the fuse breaking. I'll try tomorrow and see how it goes.. I dont want to start a new post, but how can i make the center dome light from falling down after i replaced it with aftermarket bulbs, as well as the rear view mirrow, I cant seem to get those bulbs out, I dont want to break them, that would make it worse, but is there an easy way to get those out?? Thanks...
