11-08-2014, 11:12 AM
#21
Hood is off, fender removed wont be any help. Lol
Originally Posted by Oldsnut
Originally Posted by tipnitty
11-08-2014, 10:40 PM
#22
Do you plan on dropping the whole subframe out of the car? Take the engine and transmission out as one unit? Probably be the easiest route aside from lifting the body off of it.
11-08-2014, 11:17 PM
#23
Sleepy's money pit......
1999 Pontiac Grand AM SE - 3500 Swap
11-09-2014, 12:04 AM
#24
She is but also fun.
Yes dropping the cradle and dropping motor and trans as one out the bottom.
11-10-2014, 09:35 PM
#25
Getting closer to pulling
11-10-2014, 11:11 PM
#26
I woulnd have removed the intake, but if I did, I would have put a rag in each port
11-10-2014, 11:35 PM
#27
I did when i was done for the day, i had to remove the UIM to disconnect the fuel lines that are under the UIM.
I have rags in each LIM port, all head ports, and both holes on the front and rear valve cover. (Pcv line holes)
11-11-2014, 08:17 PM
#28
So how are you going to get enough clearance to drop it all out through the bottom?
11-11-2014, 10:02 PM
#29
Drop the subframe with it is what i was suggested to do by Milzy.
11-11-2014, 10:06 PM
#30
And then lift the car off of it and roll the engine out from under it?
Ruby: 2000 Alero GLS Sedan (totaled and repaired x3) ~120k
Cherry: 2004 Alero GLS Sedan (Final 500 #362) ~63k
11-12-2014, 08:02 AM
#31
Exactly. Engine, trans, and some suspension pieces will all come out as a unit
11-12-2014, 09:43 AM
#32
But you're still probably going to need 4-6 feet of clearance under the car in order to do that, so you're going to need either a ceiling beam mounted hoist or really tall jack stands to get the car jacked up that high without a lift. Getting the engine & subframe sitting on the ground is no problem, but sliding it all out from underneath the car might be a different kind of challenge.
11-12-2014, 10:00 AM
#33
He's got tractors lol should be fine finding enough lift space lol!
11-12-2014, 12:14 PM
#34
you checked the shift linkage and all related components before deciding to completely tear everything apart right?
11-12-2014, 05:25 PM
#35
Yes. Everything external is working as it should be.
Like tim said i have a tractor if need be. Lol
But yeah basically roll out out as a whole, i can possibly get by not dropping everything on the sides that is connected to the rack
11-23-2014, 09:26 PM
#36
Welp, they are out.
11-24-2014, 09:02 PM
#37
looks dirty as eff!!!!
12-09-2014, 05:49 PM
#38
Sorry for no updates, motor and trans are sitting right now, im working on getting money together to get the trans built by FMSR. Also if everything works out, ill be replacing some suspension parts, maybe a new oil pump for safety while its out, possibly a new rack, and some other small stuff, water pump, and hopefully MMS headers. Im tired of my ragedy pacesetters. Lol
12-09-2014, 07:20 PM
#39
Whatcha doing suspension wise? You should detail the hell out of that engine bay while it's empty
12-10-2014, 07:22 AM
#40
Yeah that will be cleaned and just sway bar end links and what not. Nothing special.
