12-14-2013, 09:23 PM
#21
Not doing 80 down the interstate its not! LOL And its the Converter switch that is more important, both those work together there
12-14-2013, 10:59 PM
#22
Originally Posted by MMGT1
Did you test the switches with an ohms meter though to ensure they are functioning properly? That video is a carbon copy of what happened here.
I was going to but the battery was dead...I will check it at some point
12-15-2013, 08:53 PM
#23
You mean the brake light switch is a double pole switch?
12-15-2013, 09:44 PM
#24
There are two switches there
12-16-2013, 10:29 AM
#25
also remember that we are now on winter blend fuel. (you guys do that too, right?) my mileage has dropped from 26 to 18 (mixed driving) over the last 2 months.
12-16-2013, 11:19 AM
#26
That's what a double pole switch is. On my other car there is one switch which is used by everything.
12-16-2013, 03:43 PM
#27
You got it. But, I cant remember which is the brake and which is the TCC. You could depress each individually and see which one activates the brake lamp and then test the other is the best I can come up with.
12-18-2013, 11:41 AM
#28
If you can depress either one, then that's two single pole switches.
05-15-2014, 07:30 PM
#29
MMGT1, Can you update the photos in your original post, I seem to be having a similar issue and would like to try this.
05-15-2014, 08:42 PM
#30
If you have to replace them do both...i only did the inboard side and it only fixed half the problem...new ac delco from the stealership is under $20 a piece so really not worth the extra time
05-19-2014, 07:18 PM
#31
It turns out that my problem was the A/C being on without the light working, so as soon as I turned it off, everything was shifting normal again.
