12-22-2010, 04:45 PM
#21
Its..... about 6 inches to the left of your oil filter if your under the car and feet pointed to the front end.
Originally Posted by Oldsnut
Originally Posted by tipnitty
12-22-2010, 10:17 PM
#22
this is really starting to annoy me. Where am i going to find the right adapter for this to fit?
2003 Olds Alero 2.2L Eco
Ttop191: who gives a damn what everyone else thinks, if you are proud of it thats all that matters, dont let others persuade you into thinking what you like is wrong.
12-22-2010, 10:36 PM
#23
Auto part store will have it. You need one end of the adapter to fit in the block and the other end to fit on the new adapter
12-22-2010, 10:55 PM
#24
Edit:
i went to part source and they said theres no adapter for that because the factory has the threads that tighten when it screws in (spaced bigger to thinner) versus all evenly spaced (equally spaced)
12-22-2010, 11:59 PM
#25
i bought an adapter, and installed my oil pressure sensor.
http://www.summitracing.com/parts/ATM-2278/
12-23-2010, 12:50 AM
#26
That's weird cause I got mine from Napa with no problems.. and on my post above I ment "the other end to fit the new sensor" not adapter. But hope u knew what I ment.
Sorry if it was confusing.
12-23-2010, 02:14 AM
#27
So what would i need to take to napa for them to get me the right part? just the old sensor and the new one?
12-23-2010, 12:25 PM
#28
yeah tell them you need an adapter. you need one the size of the old sender to fit in to the oil pressure hole. and the other end needs to screw on to your new oil sender.
take both senders in if you can so they can match the threads that will go into the block.
make sure you use thread tape (i forget the reap word for it) on the adapter or your will leak some oil. mine did for awhile and had to fix it.
12-23-2010, 04:09 PM
#29
i went to part source, canadian tire, napa, princess auto, and like 3 other stores. all of them said that theres no thread adaptor because thats not a normal thread size its made for only that engine block. The guy said i should go mechanical because theres no fitment issue. So im fed up with this and am probably going to put the stock back in and forget about the entire thing. Although before i give up, theres one last thing i can try. He mentioned something about using the stock sensor but tapping into it under the dash and using a resistor for an electronic gauge. Can someone explain what he was talking about?
12-24-2010, 02:01 PM
#30
I have no idea on that but That's weird I got one for mine no problem.. but u could always order one off summit racing from the link That Guy posted for you.
