Old 02-04-2012, 01:53 PM   #21
irondiezl3
irondiezl3's Avatar
thats exactly what i did now i just wait in fear for a ses to come back on
Old 02-04-2012, 02:03 PM   #22
Conditions for Clearing the MIL/DTC
• The control module turns OFF the malfunction indicator lamp (MIL) after 3 consecutive ignition cycles that the diagnostic runs and does not fail.
• A current DTC, Last Test Failed, clears when the diagnostic runs and passes.
• A history DTC clears after 40 consecutive warm-up cycles, if no failures are reported by this or any other emission related diagnostic.
• Clear the MIL and the DTC with a scan tool.
thats wahts needs to clear the code. unhooking the battery will count as a scan tool lol
Old 02-04-2012, 02:14 PM   #23
irondiezl3
irondiezl3's Avatar
holy sh*t 40 dam i got a ways to go
Old 02-04-2012, 02:19 PM   #24
no. it takes 3 cycles to clear a "current code" (light on). lets say the light turns its self off while your driving.. then the code turning the light on becomes a "history" code. it takes 40 cycles for the ecm to clear the history code. if the lights off, then you dont have any current codes commanding the light on. so your good for now.
Old 02-04-2012, 02:20 PM   #25
make sure to do this for 3 ignition cycles (shouldnt be hard. think about this.. drive 10 miles and you have completed one ignition cycle)
• The engine has been running longer than 10 minutes.
• The engine coolant temperature (ECT) is between 76–124°C (169–255°F).
• The barometric pressure (BARO) is above 75 kPa.
• The vehicle is in Closed Loop.
• The intake air temperature (IAT) is between -20 to +100°C (-4 to +212°F).
• The battery voltage above 10.7 volts.
Old 02-04-2012, 02:23 PM   #26
irondiezl3
irondiezl3's Avatar
ive deff done 3 cycles then thats nuts if it doesnt come back on that means it was a bad 02 sensor that weasnt even that old thats nuts
you know what i just thought of. there was a thread on here in the past about rotella t6 ruining cat converters because of the add pack in it. i just put that in a couple weeks ago u never know maybe that thread was true and it did do something to the cat.
