11-03-2010, 11:20 PM
#21
Both of you thread Jesus guys... lol
My 3.4 is at 148,500miles. Running great, slight oil leak though.. :/
Edit: Yes, three thread Jesus posts at the same time
11-03-2010, 11:27 PM
#22
thread jesus... but while were at it... the ld9 blew twice in the same year...before even 60 00km on my red one(destroyed the exhaust lifter and cam and broke one cam carrier cover...)... that's why I swapped it l67...
But on the other hand I'm now a 190 000km on my black s/c ld9 with 50 000km done since boosted and I still beat it to death... still going strong....
Originally Posted by Lucalare
haha, 2 year old thread comes back to life.
11-04-2010, 12:13 AM
#23
160,021 on my clock no problems other then getting transmission rebuilt.
Originally Posted by Oldsnut
Originally Posted by tipnitty
11-04-2010, 05:35 PM
#24
Last I saw there was 196k miles on my old Alero with the 2.4L LD9 and its still going strong.
11-04-2010, 07:38 PM
#25
230k km's just rolled over it earlier and no issues with my engine, I have a lower coolant intake that needs replaced because it is seeping but no other issues with the car ( other then a po440 light )
11-05-2010, 01:19 AM
#26
190k+, and only issue is a wheel bearing sensor.
11-05-2010, 01:23 AM
#27
my car has 137,000 and it is a LA1. I have piston slap and lifter tick. I need to fix both very soon because i do not want to destroy the engine.
11-05-2010, 01:32 AM
#28
what is a piston slap and a lifter tick? Soon there will be bearing tickles...lol.
My LA1 has 112,000 and the engine and transmission are gravy. Only issue I've had is wheel bearings because I used to drive some really cruddy roads back in Ohio.
When my engine is cold and idling it seems to have a knock. I have heard this called the GM engine knock-like it is a normal thing. Diminishes as the engine warms up. Anyone have something similar?
As far as maintenance: seafoam in the oil, gas and engine prior to every oil change which I do at approximately every 5k miles. Clean my air filter every 10k miles and change my fuel filter at the recommended times.
Always wonder about advanced tune up things though like timing belt changes and such. That belt looks so damn complicated...
11-05-2010, 01:37 AM
#29
i think that is piston slap it goes away when the piston expands when the engine gets warm. if i am wrong someone please correct me.
11-05-2010, 03:00 AM
#30
2000 2.4 with 99,300 miles. 100k is coming
11-05-2010, 03:29 AM
#31
boo-effing-hoo. hahaha
11-05-2010, 08:56 AM
#32
2001 with 94k and siezed engine
stock 2.4 -building a WAI to a CAI 3A Racing muffler- ~Kicker Door speakers and Power Accustic rear speakers 10% tint 18x7.5 Alt Sonix, 2001 GLS sedan
11-05-2010, 09:32 AM
#33
seafoam can and will dry out gaskets and o-rings if used too much. I'd back off a bit...
I'm going to start using 10w30 in the summers, just cuz my oil pan gasket seems to be weeping a bit. (it might have stopped) but the engine is getting a tad noisier in its old age.
89k now. Got at least 3-4 years to go still.
11-05-2010, 10:24 AM
#34
I'm not saying it doesn't. I'm just curious about what chemical component in the seafoam that would do such things to my poor engine.
11-05-2010, 03:45 PM
#35
Xander while we have you here I got a question to ask. when you installed your HID high beams got any issue with the DRL?
11-05-2010, 04:44 PM
#36
probably the powerful cleaning solvent? if its etching oil funk off of metal... what is it doing to rubber?
11-05-2010, 04:47 PM
#37
Yes that is correct, my 3100 does the same thing too.
11-05-2010, 08:10 PM
#38
Btw it's cuz the piston can rotate a little in the bore when it's smaller.
Never looked into fixing it though.. what does it need, just new rings? Or new pistons, too?
11-06-2010, 12:32 AM
#39
It isn't for dissolving oil funk. It just loosens carbon deposits-essentially "soot" from the inside of your engine with a chemical makeup that will not damage your engine because it really isn't practical to flush your engine with water...I will say that too much of anything is a bad thing, but they would have a hard time staying in the market if it damaged engine components regularly.
Clutch, I think it is just a law of physics and nothing that can really be fixed. Unless someone is aware of a particular method.
11-06-2010, 01:00 AM
#40
well i can say i did seafoam twice and ruined an o2 sensor, which leads me to believe seafoam was the culprit, the sensor was not even a year old.
