My main reason for changing the size was that Dunlop z1 comes in limited sizes only and I had to pick something... On the tire calculator this seemed to be the closest fit.
And I do agree with you that in straight lines wider tires will most likely help... specially on dry roads. I have to worry about hydroplaning though and wider tires are more prone to that.
Back to the rims.... do you think $200 is reasonable for those?
GS - 01 Alero Coupe - MT, CG-lock,Front/rear strut tower brace,WAI,Fidanza Short throw Shifter and custom short throw clutch, AGX adjustable struts and mounts, Dropzone Springs, speedbuilt front sway bar, Toyo R888.
CS - 06 RX8 - Special Edition Shinka, 285 Hoosier A6.
