10-04-2008, 03:32 AM
#21
Originally Posted by Cliff8928
Did you check the "INT LPS" fuse in the passenger side fuse panel?
Yes, I checked ALL of the fuses, twice.
10-04-2008, 03:43 AM
#22
yea fuses arnt the problem, i have checked several times
10-04-2008, 04:03 AM
#23
Could be a BCM issue...
10-04-2008, 10:51 AM
#24
So that ultimately the decision maker on when to send current to the lighting, after signals are sent from the doors?
10-04-2008, 11:14 AM
#25
basically.
your signal wires come from the sensors into the fuses, then to the BCM then back out to their destinations.
12-16-2008, 04:26 PM
#26
if they are in a series circuit a out light will cause it?
12-16-2008, 04:32 PM
#27
No they are not wired in series.
12-16-2008, 04:34 PM
#28
are they still out? check to make sure your emergency brake is all the way down (pull it, then put it up, then drop it all the way back down)
12-16-2008, 04:46 PM
#29
They now work intermittently. And what would the e brake have todo with anything?
12-16-2008, 05:13 PM
#30
i noticed with my ebrake pulled, my interior lights didn't turn on, from when the car is off. don't know why.. but they didn't.
it really messed with me the first few times i was finishing an LED project. get everything wired, then BAM don't work. WTF!! put that back down, and they click on immediately.
12-16-2008, 05:24 PM
#31
Weird. Well I don't use the ebrake, so anyways...
12-16-2008, 05:47 PM
#32
hmm, check anyway?. not fuses. not ebrake.... odd
check fuse box bolts(both sides), to make sure they are tight?
pull your BCM out, and see if its intact/uncorroded?
12-16-2008, 06:14 PM
#33
Its alright, I don't care about it anymore....
12-16-2008, 08:16 PM
#34
The interior lights do not come on if you have your e-brake pulled up. I guess thats a "feature" with our cars.
12-17-2008, 02:38 AM
#35
I don't use the ebrake, its an auto......
12-17-2008, 02:20 PM
#36
Unplug your battery and leave it off for like an hour. Then reconnect.
The EXACT same thing happened with my Aurora when I changed my headlights (relation between the 2? Hell if I know.), no courtest interior lamps, but they came on with a switch, and the radio wouldn't stay on after the key was off. Also the Key FOB didn't work.
My battery went dead one night that I left the interior lamps on w/ the dimmer switch, and when I jumpstarted it everything worked and has been working sense. My guess is it reset something in the BCM.
12-17-2008, 03:31 PM
#37
I've already done that a bunch of times for other reasons.
