08-21-2008, 12:48 AM
#21
Originally Posted by Midgear
let er' sit for a good 15 - 30 minutes.. have you a couple beers while you're waiting..
im not sure if theres a specific way to depressurize the system.. but hell its not like its going to explode in a firey vortex of flames that engulf your face and destroy your house and kill all your animals.
was that to much detail?
hahaha no.. if that did happen it would b my parents house, and the only animal is me hahahahahahahahahahahaha
08-21-2008, 01:04 AM
#22
yea there is actually. i'll post tommorow after i look at the GM manuals at work. but for a 2.4 its unplug the harness by the fuel pump, start the car and let it die, do a couple dry cranks, and your ready to go.
08-21-2008, 01:18 AM
#23
ok.. great thank you
08-22-2008, 02:30 AM
#24
i couldnt find any trace of a leak in the rail, or injectors.
08-22-2008, 02:35 AM
#25
hmm... pressure leak only when car is running?
08-22-2008, 04:35 AM
#26
Is the car running bad otherwise.
Plugs could be fouled
08-22-2008, 08:26 AM
#27
Power steering
I believe the power steering on these motors is driven by the cam drive belt.
08-22-2008, 10:54 AM
#28
there's no belt, it's gear driven
to empty the fuel system to remove the rail/injectors you pull the fuse for the fuel pump, start it, it dies, crank it for a while afterward.
it didn't seem to work too well, heh.
08-22-2008, 12:12 PM
#29
thats what im thinking, but i havent gotten my hands on a gauge to check it yet.. and i dont wanna spend 50 for a gauge im only gonna use this once lol.. but yea im prolly gonna have to bring it to a shop then? and have em smog it.
ill check the injectors one more time just to see.
08-22-2008, 01:54 PM
#30
Ditto
Steering pump is gear driven. If you take the fuel rail out, you wont get any leaks as long as you dont pull the injectors. Otherwise, even if you depressurize the system, you'll have a good amount of fuel leaking everywhere on your engine , been there done that.
08-22-2008, 02:14 PM
#31
i looked again. and i did happen to find a dried spot thats stained.. not sure if its fuel, or from the tranny.. and yes i smelled it to see if it reaked of fuel, but i didnt really smell nething.. snd i wouldnt think that if it was gas the smell would linger forever anyway
im gonna take a pic later, then post it up, for the opinions of yal good folks.
08-22-2008, 02:44 PM
#32
i'd just poke around with a torch until you find it...
08-22-2008, 04:07 PM
#33
i changed the plugs 15000 miles ago.. its idling at close to 1000rpm, but im not sure why.. which could be another question. what would cause that?
08-22-2008, 04:09 PM
#34
hahahahaha uumm. yea me and fire dont get along, things usually go BOOM!! so yea that prolly woudnt b a good idea with me.
and plus doing that is just plain stupid!
08-22-2008, 10:56 PM
#35
I think i figured out the problem...
Im almost positive that it is the Fuel Sending unit.. which means i needa new pump.
Because ive been researching, and talking to friends, and that is the conclusion we are coming to. since everything tuneup wise has been done, and no puddles have been found, or lights on the dash.
Ill check that tomorrow, and hopefully thats it
08-28-2008, 07:13 PM
#36
still havent found the issue. dont wanna replace pump til i know for sure.. i was, however, talkign to a few ppl and said that it could be the PCV valve.
Because now the car is idling at 1000-1500 rpm. thats not normal
Thoughts?
08-28-2008, 07:34 PM
#37
I saw this thread and I have a gas leak thats coming from this part... but it only happens when the engine is cold or pretty close to it... I have no idea whats its called... any help would be awesome
08-28-2008, 08:03 PM
#38
That would be the Fuel Pressure Regulator...they have a tendency to leak. gotta change it out.. i had to do the same on my 3400 when i first got it
2001 Oldsmobile Alero GL Sedan LA1 3400 SFI V6
Nickname : Midnyte
08-28-2008, 08:10 PM
#39
Thanks for the info... i could see the gas running from it when i cranked on a cold start...
And 02AleroEco i apologize for stealing your thread for a sec
#40
Do u have an Eco engine??
