before it goes in the shop
2004 90k have had this issue for a year every shop tells me its something i get it replaced problem still exists and has worsened to the point where its scary to drive. heres the issue very very rough and heavy vibrating especially over 40mph but at all speeds. i have had 3 shops tell me its 3 things so i have replaced the following, rear struts, all 4 tires roadforce balanced tires replaced twice, rims checked for being bent, every part of the braking system including stainless lines and fluid flush and fill, only braking part not replaced were my caliper which i was told by all 3 shops r fine. there is no noise whatsoever from this issue just the feeling the hard rough shaking vibrating ride thats so intense u can feel it in the entire vehicle and my frame is not bent either. what are some things that can cause this so i have some idea before i go in the shop once again and spend more money to find i still have the problem ive never had a issue like this in the past if i had a problem i just got it fixed boom done. any tips really appretiated.
