Old 06-02-2009, 12:25 AM   #21
bdyman
its not to bad, one thing disconnect the battery, the passenger air bag should be removed, it really is one of those things that you have to go as you see the bolts and clips, thats the way i do it when i have to, i take my time remove the parts that need to be that stuff is real obvious
and be careful that you dont break anything
Old 06-02-2009, 12:32 AM   #22
AleroDrime
The Aleromod PITA
AleroDrime's Avatar
this sounds stupid i know but some masking tape and color markers call help, attact tape to any screws or bolts, color and label then put tape over the hole the screw went in, color and label
Old 06-02-2009, 01:00 AM   #23
bdyman
no not stupid marking bolts is fine, i just use baggies and label them instead
Old 06-03-2009, 05:02 PM   #24
AleroChick785
AleroChick785's Avatar
AleroChick785 is on a distinguished road
u have to remove the airbag before taking out the dash? i believe i got all the screws out from my dash..i tugged on it..an then i think i'm missing something that needs to be takin off
http://www.cardomain.com/ride/3318093
AleroChick785 is offline   Reply With Quote
Old 06-04-2009, 12:43 AM   #25
AleroDrime
The Aleromod PITA
AleroDrime's Avatar
thats similar to my uncles method when he takes apart old cars, but i find that method, easier to do, and easier to match up
