Old 05-09-2006, 01:27 AM   #1
RoninKouga
hi there!
how were u guys doing?
i got a serious problem w/ my ho i think. from one day on it started to leak out hydraulic oil, i gotta refill at least 0,2liter per day (all 30 mls).
i sthis a known probem? does anyone have experience with the steering? i thought (hope) it may be a tube in this system since i duno if the system contains tubes or just stiff pipes.
can sum1 help me w/ this topic?
greetings from germany
ronin
Old 05-12-2006, 04:35 AM   #2
RoninKouga
lifted the car and didnt see anything but black oil
oke i found out that there is a plastic tube from the hydraulics compresser to the steering. can anyone help me by providing the parts number of this tube?
Old 05-12-2006, 04:54 AM   #3
freakout
freakout's Avatar
freakout is an unknown quantity at this point
By the "hydralic's compresser" I think you mean the power steering pump. Is it the pressure or return line? The return line is help on with clamps. The pressure line has fittings. If it's the return line, any good quality hose will be fine. The pressure line maybe a hydralic shop could make it for you? Do you have to order parts from over here? If so might be cheaper to have it made.
What a great damn day, I can walk!
freakout is offline   Reply With Quote
Old 05-16-2006, 03:03 AM   #4
RoninKouga
hi thanx for your reply. yeah, i ment teh hydraulpcs pump. id chamge both tubes if i found them to order, cuz i dun have the chance to remove them for more then a day to give them the tubemaker and wait til theire done. are this parts as expensive? (where to buy?) ;_;
thx in advance
ron
Old 05-19-2006, 02:34 AM   #5
freakout
freakout's Avatar
Here's a spot you might be able to buy them. But I don't know any part numbers. Hope this helps. http://www.gmpartsdirect.com/partsvoice/frameset.cfm
