My driveway has a 'hump' or 'berm' at the top as you enter/exit the driveway. It scrapes the heat shield every time due to the low clearance.
It sounds like of you slid the flat side of a metal yard rake over an open weave metal sidewalk grate. Can't describe it in words, but that is the best 'visual' i can give.
It's easy to see and inspect. If there are no bends, folds, tears, or fresh scrape marks, then at least you can eliminate it as a suspect.
'03 Ruby Red GL1 4 Dr, Ecotec auto. All options but leather. 16 inch factory Argent wheel upgrade, Potenza RE910s, Powerslot front rotors, factory deleted cargo net replaced. Hi/lo beam Silverstars.
