Go Back   Aleromod.com > Performance Related > At The Track
Old 11-28-2013, 12:42 AM   #1
Breaking 12s, the hard way
https://www.youtube.com/watch?v=f3DXj1lbj4U
Saturday Fun Racing
Beech Bend Raceway, 11-23-13
Stock engine, custom trans, LS1 MAF, TCI 68 mm TB, TOG headers, 3 inch Magnaflow exhaust, no resonator, no air filter, Racetronix pump, stock fpr, 36 lb injectors, MSD ignition, stock coils, MP90 supercharger, no intercooler, M&H 8.5x23 slicks.
Nice cold day to race! It took two passes to get the tire pressure dialed in. The first one was almost a disaster, according to the scan -- had severe misfires on #4 and #3. By the third pass they almost disappeared, and I got in 3 decent runs. Here are some stats on the best run:
Ambient Temp -- approx. 50* F
Intake manifold temps:
IAT before burnout -- 68* F
IAT after burnout -- 142* F
IAT, start of run -- 97* F
IAT, end of run -- 167* F
ECT: 194*-- 198* F
Car#-----B888
R/T------.118
60'-----1.839
330-----5.306
1/8-----8.205
MPH-----85.37
1000----10.769
1/4-----12.951
MPH-----104.48
Noteworthy on the scan was a healthy amount of KR, more so going into 3rd gear, and the O2s tapering off to 900 mv (yet the IDC and pulse width not too high), hint of misfire on #3 at about 96 mph. 0-60, 4.439 sec.
Old 11-28-2013, 12:50 PM   #2
I think you need those 60's man. Above 80% they just cant open and close fast enough to keep fuel mix proper. The time it takes to charge the pintle, open it, then close it... you know what I mean man. You could try a pressure regulator too, if you set pressure to 58psi those 36's then equate to around 42's.
But holy hell she's putting it down dude!!! Fookin' A+++ bro! Hahahaha
Old 11-28-2013, 12:53 PM   #3
295 ft lbs of tq. Mmm
Old 11-28-2013, 01:21 PM   #4
guiguilandry
guiguilandry's Avatar
Nice !!!! Congratz
Custom or Nothing...
www.demonautosport.ca
Old 11-28-2013, 11:56 PM   #5
THats at the shift man! Look at what he is hitting from the get go!! B, you gotta go for the 6400 RPM shift man, that thing is an animal
Old 11-29-2013, 02:28 PM   #6
Babyblue
Babyblue's Avatar
Babyblue is on a distinguished road
how do you get that supercharger? are they even made anymore?
Babyblue is offline   Reply With Quote
Old 12-03-2013, 08:42 AM   #7
Nas Escobar
Nas Escobar's Avatar
I like that supercharger.... Any way you can make it a 10 second car, or are you stuck in 12s?
1994 Olds Cutlass Supreme
1996 Infiniti G20
1993 Chevrolet Lumina Z34
1989 Buick Regal Limited
Old 12-03-2013, 02:43 PM   #8
MilzyZ34
MilzyZ34 has a reputation beyond reputeMilzyZ34 has a reputation beyond reputeMilzyZ34 has a reputation beyond reputeMilzyZ34 has a reputation beyond reputeMilzyZ34 has a reputation beyond reputeMilzyZ34 has a reputation beyond reputeMilzyZ34 has a reputation beyond reputeMilzyZ34 has a reputation beyond reputeMilzyZ34 has a reputation beyond reputeMilzyZ34 has a reputation beyond reputeMilzyZ34 has a reputation beyond repute
Send a message via AIM to MilzyZ34
any wideband data to go along with the scan with the KR?
www.milzymotorsports.com
MilzyZ34 is offline   Reply With Quote
Old 12-03-2013, 02:48 PM   #9
MilzyZ34
by the way, it's not the best way to calculate AFR, but if the O2 sensor is in the .9xx's, that's a little bit rich, so leaning it out will help you get a little bit more out of the injectors, although if you can't get the pulsewidths below 20, you really need bigger injectors. You need to use a wideband to measure it and see how much to lean it out.
Old 12-03-2013, 06:50 PM   #10
cavedewler
cavedewler is infamous around these partscavedewler is infamous around these partscavedewler is infamous around these partscavedewler is infamous around these partscavedewler is infamous around these partscavedewler is infamous around these partscavedewler is infamous around these partscavedewler is infamous around these partscavedewler is infamous around these partscavedewler is infamous around these partscavedewler is infamous around these parts
what is the extra reservoir for in front of the coolant reservoir?
cavedewler is offline   Reply With Quote
Old 12-03-2013, 10:18 PM   #11
Its boost juice bro
Old 12-04-2013, 08:41 PM   #12
cavedewler
^ Lol
Old 12-05-2013, 12:02 AM   #13
re-routed washer fluid would be my guess...
Old 12-05-2013, 03:10 PM   #14
MilzyZ34
I do have to say though, it's about damn time someone put the right sized blower on one of these cars.
Old 12-05-2013, 10:08 PM   #15
What would a mp112 do on this... or is it to big
Old 12-05-2013, 11:33 PM   #16
guiguilandry
it's almost too big for my 3800 so I think that on a 3400 it's definatelly too big...
Old 12-06-2013, 01:47 PM   #17
MilzyZ34
yeah I think a MP112 would be a bit overkill on a 3400. On a 3800, all it pretty much does is add a bunch of torque, which the 3800 already has plenty of. To give you an idea, by the time you make the decision to go with a MP112, you've probably already done everything else. When I demoded my monte carlo a few years ago, I put all the parts onto a grand prix, along with our prototype intercooler, and with a slipping supercharger pulley hub, the car made something like 350whp and 460ft-lbs at the wheels with 9psi. Now if you add a MP112, how useful is the extra torque going to be when the car already breaks the tires loose at 40-50mph.
Old 12-06-2013, 03:35 PM   #18
guiguilandry
well it's gonna be just pure insanity... with a 5 speed f23...hello torque steer, lol... spinning tires at 60-65mph on the highway is gonna be scary...
