06-16-2009, 08:23 AM
Sheetmetal question
So I want to drill a 9/16" hole through the roof of my car to run an antenna for my satellite radio. I'm tired of the water running along the antenna wire and leaking into the car the way it is set up now. What is the best way to drill cleanly through the sheetmetal. I haven't had the best of luck with that "cleanly" part in the past. Suggestions/tips/etc?
06-16-2009, 08:46 AM
Just buy a regular antenna mount. It has a seal and doesn't leak.
06-16-2009, 09:07 AM
What exactly are you referring to by "regular antenna mount"? The sat radio antenna has a wire run through my door jamb to the cabin of the vehicle. Water is slipping past the weatherstrip that way.
06-16-2009, 09:15 AM
I'll get a pic of one later this week.
06-16-2009, 04:47 PM
stick it to the inside of your rear window thats how i have mine cause i got sick of the water leaking in
06-17-2009, 07:08 AM
Do you notice any difference in reception that way?
06-17-2009, 11:03 AM
Just go slow with the drill and use a smaller size then go larger.
Do you have a factory XM antenna that you're using?
06-17-2009, 11:36 AM
No, I was going to get a marine style Sirius antenna, unless a factory XM antenna will connect to and work with my Sirius receiver.
06-17-2009, 11:40 AM
Yeah, it works fine with the XM antenna on sirius.
06-17-2009, 11:41 AM
Maybe I'll look for a factory antenna on fleabay then.
06-17-2009, 03:02 PM
With mine i just ran it down the weather strip. Mine had a small lip that pulled back on the weather strip, and i just tucked the wire in there and ran it down the door then around to the dash.
06-17-2009, 05:12 PM
step bit, if you have one.
06-17-2009, 05:55 PM
Nope works just fine and i also have an xm antenna plugged into my sirius
06-17-2009, 07:45 PM
Go slow with a step bit and an XM antenna will work...good info guys. Will have to evaluate inside of the window vs. drilling now. Thanks all.
10-10-2009, 08:44 PM
Dont drill anything, just run the anti. out the back and up to the rear trunk.
10-10-2009, 09:13 PM
I'm long past this now. The car will be in the scrap yard by the end of the month. But thanks anyway.
10-10-2009, 10:50 PM
was wondering why no-one else mentioned this... but obviously... this can be closed now.
10-11-2009, 12:37 AM
pull up the seal and tuck it into it and run it thats what i did with my nav antenna, no problems... ill get pictures tommorow.
NVM i skimmed before i read it all.
146.7dBTL Pro No-Wall www.teamnortheastspl.com
SUB: 15" alumaproDeck: Pioneer AVIC-D3 Amps:rf 500bd, Rf 200A2, Rf 160aII currently lacking big audio. video of current:YOUTUBE
10-13-2009, 11:06 AM
if you want to see what would happen if you tried drilling through the car, you can get all the practice you want now.
10-13-2009, 11:09 AM
True enough
