Old 01-22-2006, 04:21 PM   #1
AndysGX
AndysGX is an unknown quantity at this point
What you will need:
Ratchet wrench with 6 inch extension
Spark plug socket. Make sure it isn't very large around (diameter). It's a tight fit.....
13mm socket
8mm socket
needle nose pliers
4 spark plugs
Pop the hood obviously.....
Not shown: Disconnect the negative (black) battery cable using 8mm socket.
Disconnect this electric plug on the driver's side of the cam cover. (don't know what it is. any help?)
Using 13mm socket, remove the 4 cam cover bolts.
Remove cam cover. It won't come easily, but will take some force.
Use needle nose pliers to remove spark plug boots.
Clip the boots back on to this thing. (what the hell is that anyway? coil pack?)
Use spark plug socket and 6 inch extension to remove plugs. I had to use a 3 inch. It made a 20 second removal take 5 minutes on each plug.
Out with the bad. (70k miles)
In with the new. (.050 gap)
Reverse the steps above to reinstall everything.
Any questions?
2000 Alero coupe
APoC intake
Powerslot rotors
ARE wheels
Aleromod member: THE EARTH IS ONLY ABOUT 6000 YEARS OLD
And these people can vote and drive on public roads....
AndysGX is offline   Reply With Quote
Old 01-22-2006, 08:41 PM   #2
AlbinoMonkeyRat
Let's Play Army!
AlbinoMonkeyRat's Avatar
that little thing you unplug to pull the cover off *I think* is the ignition module. Controls the sparking of the plugs. Clarification?
One question on this: without using a torque wrench, how do you know the spark plugs are in all the way?
Aside from that, good job dude!
Old 01-22-2006, 09:09 PM   #3
Vtolds
H&B Shipping Agent
Vtolds's Avatar
If you dont have a torque wrench, just a firm tug of the ratchet to tighten them. Maby someone else can explain it a little better.
Old 01-22-2006, 10:49 PM   #4
Mr_White
Mile High Club
Mr_White's Avatar
Mr_White is an unknown quantity at this point
nice job dude
now all thats left is a good wash job on that engine bay
http://www.aleromod.com/forums/image.php?type=sigpic&userid=1988&dateline=1166644  267
Mr_White is offline   Reply With Quote
Old 01-23-2006, 01:02 AM   #5
Lovestheh20
good post bro.
Old 01-23-2006, 09:41 AM   #6
AndysGX
Originally posted by AlbinoMonkeyRat+Jan 23 2006, 01:41 AM--><div class='quotetop'>QUOTE(AlbinoMonkeyRat @ Jan 23 2006, 01:41 AM)</div><div class='quotemain'>One question on this: without using a torque wrench, how do you know the spark plugs are in all the way?
[/b]
I just wrenched on em until it took a LOT of force to turn any farther. Not the best way to do it, but the car runs fine.....
<!--QuoteBegin-Mr_White
@Jan 23 2006, 03:49 AM
nice job dude
[/quote]
LMAO. I knew someone was going to say something about that....
2000 Alero coupe
APoC intake
Powerslot rotors
ARE wheels
Old 01-23-2006, 09:52 AM   #7
good info andy...keep up the good work
Old 01-23-2006, 07:15 PM   #8
Mr_White
Mile High Club
Mr_White's Avatar
Originally posted by AndysGX+Jan 23 2006, 07:41 AM--><div class='quotetop'>QUOTE(AndysGX @ Jan 23 2006, 07:41 AM)</div><div class='quotemain'>
nice job dude
[/b][/quote]
I think if you wrench em to much the next time you go to change them they might be female dog to get out (from heat expansion)
Old 01-23-2006, 08:19 PM   #9
Fast Eddie
Fast Eddie is an unknown quantity at this point
Send a message via AIM to Fast Eddie Send a message via Yahoo to Fast Eddie
Just put some never-cease on em
of course you could also cross thread em, if they are not in correct, or the head could also crack.
I'm on a boat.....
Fast Eddie is offline   Reply With Quote
Old 03-17-2006, 11:39 AM   #10
lol... correct hand torque is 1/4 turn back from the tightest you can get them.... haha...
(joke)
Old 03-19-2006, 12:32 AM   #11
The big white thing that the boots clip on to is called a Coil Cover or Coil Housing. That electrical plug was in fact removed from the ignition module. And the big aluminum piece that you removed that says "2.4L Twin-Cam" is the IDI (Integrated Direct Ignition) cover. The cam covers are the ones that mention the spark plug torque on them that actually cover the cams.
