Old 08-04-2006, 12:04 AM   #1
NFS
Exclamation HA!!! no more stupid DRL
I hate DRL's so I was determined to find out how to disable them. Take Relay 22 under the hood and snip pin 78 not 78a just 78 and plug it back in. No more DRL, the ARM module doesn't care about seeing power go to the high beams all it cares about is see power and ground from the relay.
Old 08-04-2006, 12:32 AM   #2
acold7dusta
so how do u turn the lights on?
Old 08-04-2006, 12:35 AM   #3
alerocar01
alerocar01's Avatar
alerocar01 is an unknown quantity at this point
buy a new relay
alerocar01 is offline   Reply With Quote
Old 08-04-2006, 12:35 AM   #4
electrical tape works much easier...
Old 08-04-2006, 12:40 AM   #5
NFS
Here's the thing, The ARM module sends out a signal to to R22 provides low power to the high beams in the daytime. When pin 87 is snipped it cuts power on that circuit. Your low beam and high beam will still work.
Old 08-04-2006, 12:41 AM   #6
the tape just cuts off the signal
Old 08-04-2006, 12:43 AM   #7
NFS
Just snip it and plug it back in
Old 08-04-2006, 12:57 AM   #8
Which pin do you clip to have hi and low beams on at the smae time (when switched of course)
Old 08-04-2006, 03:49 AM   #9
sound_xtreme
sound_xtreme's Avatar
ya, this is a known fact. i thought there was a how to somewhere on here. brent does it almost every year to peoples cars at ASS. ive done it for a couple local grand am and aleros here
Cardomain
Old 08-04-2006, 04:15 AM   #10
I've seen the thread, but when I had the time to do it, I lost it
Old 08-04-2006, 05:35 PM   #11
Mr_White
Mile High Club
Mr_White's Avatar
Mr_White is an unknown quantity at this point
does this work on all years
because the 99 uses high beams as the DRL's
http://www.aleromod.com/forums/image.php?type=sigpic&userid=1988&dateline=1166644  267
Mr_White is offline   Reply With Quote
Old 08-04-2006, 07:20 PM   #12
freakout
freakout's Avatar
freakout is an unknown quantity at this point
Is this the one ya mean? http://www.aleromod.com/forums/showt...ght=highs+lows Here is a website for info on disabling DRLs http://www.lightsout.org/disable.html .
freakout is offline   Reply With Quote
Old 06-02-2007, 12:29 AM   #13
AsianAlero
AsianAlero is on a distinguished road
Send a message via AIM to AsianAlero
i did this a while ago on my car and it worked but my left high beam doesnt work and i dont know if this is why its not working..
AsianAlero is offline   Reply With Quote
Old 06-02-2007, 10:15 AM   #14
Oldsman
Owner
Oldsman's Avatar
NO it don't..................Brent did mine and now my lights are effed up. Not brent's fault but more the 99 fault. it worked for awhile but now the high beams are dim as shit and on with the lows and a SVS light also. It's just effed up.
Beware of the BackStabber
Old 06-02-2007, 01:35 PM   #15
you should be able to just unplug the DRL resistor to get them to go off.
Old 06-02-2007, 06:34 PM   #16
strtrydr
strtrydr's Avatar
^ nope you will get a damn SVS light
Old 06-02-2007, 06:47 PM   #17
SweetNLow
SweetNLow's Avatar
scott i dont think its the fact that i got rid of your DRL's thats effecting your high beams.
cutting off the drl's the way i do them buy slipping just a piece of electrical tape between the contact in the DRL relay in no way should make a difference in your highbeams.
putting the tape between the contacts only results in the relay not switching "on" when it gets the signal from the computer to turn the DRL's on.
you have another issue with your high beams and its not from getting rid of your drl's.
my car is a 99 as well and ive never had an issue with my high beams after i killed my DRL's
joelsoundxtreme: u faggot
Old 06-02-2007, 08:42 PM   #18
Oldsman
Owner
Oldsman's Avatar
i have replaced bulbs and not the cause. never had an issue til you did the drl bypass. like i said i am not blaming you.
in the daytime my drl's are on but if i start it up in the garage and the lights come on it throws a SVS and then the DRL's go out. my high beams are way dim and the low beam on the driver side also. also highs and lows are on when the lights come on also.
i really need it to get scanned. i have even replaced relays and still same issue.
like i said never had an issue before but now i do right after it was done. so something happened.
Old 06-04-2007, 02:26 PM   #19
Did you check the headlight grounds for that issue? I just recently had to clean up the splice-pack on my drivers side fender because my turn signal went all crazy.
Old 06-22-2007, 03:45 PM   #20
SLVRalero
SLVRalero's Avatar
SLVRalero is on a distinguished road
Send a message via MSN to SLVRalero Send a message via Yahoo to SLVRalero
I Got A 2001 Alero And I've Been Meaning To Do This Simple Mod, But I Can't Find Relay 22 Under The Hood, I Need Some Help. Can Anyone Help Me Out? Im Tried Of The Low Yellow Drl's.
SLVRalero is offline   Reply With Quote
